URGENT cam installation help
Old Feb 1, 2005 | 01:08 PM
vti444's Avatar
Default URGENT cam installation help
car is at garage over here in england, u.k havin buddyclub 3+ cams, rocket gen 2 springs/retainers, itr lma and spoon headgasket fitted on my b16a2.
dropped car of yesterday and just got call sayin he's havin probs gettin cam timing right. screwed my plans up as am booked to have power fc fitted/setup in mornin.
i have no tech knowledge so hopin you guys can give me some info i can pass onto him. he said he tried to set accordin to spec sheets that come with them 100/102 deg with my toda pullies that were already on but cant get timin right.
dont know anyone over here who has fitted these cams yet so cant get any help here
please help
Old Feb 1, 2005 | 09:40 PM
teg92's Avatar
Default Re: URGENT cam installation help (vti444)
This question strikes me as slightly vague.
How is your garage determining that the timing is "not right"? What is his definition of not right... Maybe someone could better help you with a more detailed problem description! Good luck
Old Feb 1, 2005 | 11:42 PM
vti444's Avatar
Default Re: URGENT cam installation help (teg92)
sorry, thats just what the garage told me me. simply told me he couldnt get them timing set accordin to the spec sheet
do bc3+ cams install just like oem cams ? only factor that will throw timin of in my case will be the spoon headgasket ?
Modified by vti444 at 10:00 AM 2/2/2005
Old Feb 2, 2005 | 06:15 AM
milton's Avatar
do u have aftermarket cam gears?
Old Feb 2, 2005 | 06:25 AM
vti444's Avatar
Default Re: URGENT cam installation help (milton)
problem sorted, guy just said he found my toda gears hard to work with as had never used them before . i now have idling problem
https://honda-tech.com/zerothread?id=1135880
Old Feb 2, 2005 | 11:07 AM
Used2beAb16's Avatar
Need to play with the gears now and find a way to get it to idle, try some advance, in small increments.
maybol1j
27
Apr 21, 2009 09:31 PM
wangan_DA9
Nov 1, 2004 06:39 PM
cubancrx
Apr 16, 2004 07:49 PM
hlhneast
Mar 1, 2004 08:54 PM
2fcknfst
Apr 29, 2002 08:08 PM
