will a p07 work in a non vtec car?
Old Feb 1, 2005 | 08:02 AM
slowturbocx's Avatar
Default will a p07 work in a non vtec car?
will a p07 work in a non vtec car? i want to convert a obd 0 integra to obd1 and its not vtec but i plan on using uberdata will it work? thanks
Old Feb 1, 2005 | 09:29 AM
mmuller's Avatar
Mad Scientist
Default Re: will a p07 work in a non vtec car? (slowturbocx)
yes, just disable vtec and only use 1 set of maps
Old Feb 2, 2005 | 07:57 AM
Default Re: will a p07 work in a non vtec car? (mmuller)
so iuse only one set of maps? there are usually two, right? diable the vtec? antything else im also running boost. no engine codes?
Old Mar 3, 2006 | 09:20 AM
DelSolDon's Avatar
bump for similar question:
i want to know if i can use a P07 to run a D15B8 (non-vtec CX engine) without problems. what needs to be done to the ECU, if anything? would i have to run a 5-wire O2 sensor? i am planning on having this as a high MPG daily driver. would i just be better off trying to locate a P05?
DarkDragon
Oct 29, 2005 02:43 PM
Lmgrcivic
Jan 18, 2005 02:29 PM
AZMRSi
Aug 30, 2003 11:43 AM
