input shaft bearing question
Old Feb 1, 2005 | 08:02 AM
rice a roni's Avatar
Default input shaft bearing question
i was wondering if i could get an input shaft bearing from a different d series tranny and put it in my hf tranny....anybody got an answer?
Old Feb 2, 2005 | 04:55 AM
Default Re: input shaft bearing question (tyranosauras-rex)
dude is this question to hard for you guys?
Old Feb 2, 2005 | 07:11 AM
Louie B.'s Avatar
Yes you can, but if you're tearing apart the tranny anyway, why not just get a new bearing so you know it's going to last!
I can get a complete rebuild kit (all bearings, syncros, and seals) for $200.. one bearing can't cost that much.
Old Feb 2, 2005 | 04:26 PM
Default Re: input shaft bearing question (Louie B.)
i know but im getting a tranny that has shot gears for free so i thought i'd just throw that sucka in.
Old Feb 2, 2005 | 07:39 PM
Louie B.'s Avatar
The big problem is going to be getting the "good" bearing out of the case without damaging it. If both trannies are non-si, you might be able to swap the entire front-half of the casing w/ the bearing still in it.
Old Feb 3, 2005 | 04:49 AM
yeah but the problem is that the other tranny is from a hydro and mine's a cable...am i better off getting a new tranny?
Old Feb 3, 2005 | 06:48 AM
Louie B.'s Avatar
Hydro tranny will probably have a different size input shaft bearing anyway.. I wouldn't bother.
Like I said, a new bearing doesn't cost that much by itself. I'd at least get a new input shaft seal while you're in there. The honda catalog lists 2 different part #'s so you'll need to get the old one out to make sure you get the right one.
from http://www.slhondaparts.com:
91002-PHR-003 BEARING, BALL (26X52X15) $16.13
91002-PL3-A04 BEARING, BALL (6205UC/26) (NTN CORP.) $16.13
91216-PL3-005 OIL SEAL (26X42X7) (NOK) $3.98
#'s 15,21:
d15b7inEF
20
Jan 25, 2011 06:02 PM
solo-x
29
Aug 30, 2005 02:56 PM
GruvyTune
Apr 7, 2003 06:50 AM
zerospooon
Dec 16, 2001 01:41 AM
