everything you need to know about ZC
http://www.importpoweronline.c....html
very detailed information....even tells you what other source parts to use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julio_bOostamante »</TD></TR><TR><TD CLASS="quote">wow that sites been around for a while...</TD></TR></TABLE>
I figured so...but I've seen so many questions about ZC this ZC that and no really big answers...so I figured I contribute to the list of blah blah blah..Thanks for reading this at least...
wow your right....but which is which...I've seen so many numbers..
http://www.geocities.com/chipman_13/zc.html
Engine Specs.
1.6L (1590 cc) DOHC non VTEC
125-132 hp @ 6800 rpm
http://www.geocities.com/AGGRE...E.HTM
Technical Specs
1.6L (1590cc) (97ci) DOHC
130hp @ 6800 rpm
http://www.streettuners.com/cu....html
88-91 Si ZC 4G - EF 1595 9.6 : 1 129 @
6800 rpm 106 lb/ft @
5700 rpm JAPAN
ok...I can go on and on...jtlyuk I am not here to proove a point...
thought that some of the links I found were pretty good tech info..
so its just food for thought...I cannot endorse any of these either.
I do welcome any support information for many of the HT ZC owners so please post your best.
Thanks
Engine Specs.
Technical Specs
130hp @ 6800 rpm
5700 rpm JAPAN
Thanks
Of course we can't rule out all the different '"ZC" incarnations....but on the black cover dohc, the specs straight from Honda-Japan:
130ps = 128hp
The older brown cover ZC was actually rated at 135ps(133hp)...I think that's where a lot of the confusion comes from.
Again.
130ps = 128hp
Again.
svacca1
Sep 15, 2007 06:52 PM
