Motor Mount Torque Specs for 99-00 si?
Old Jan 31, 2005 | 09:00 PM
anekin007's Avatar
Default Motor Mount Torque Specs for 99-00 si?
anyone know the torque specs for the motor mounts for a 99-00 civic si? im going to be installing the es motor mount inserts and i want the bolts torque down correctly. Thanks.
Old Feb 1, 2005 | 05:54 AM
JDM EJ1 95's Avatar
very fuking tight
Old Feb 1, 2005 | 08:51 AM
anekin007's Avatar
Default Re: (JDM EJ1 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote">very fuking tight</TD></TR></TABLE>
good answer!
Old Feb 1, 2005 | 09:20 AM
monicle's Avatar
Default Re: Motor Mount Torque Specs for 99-00 si? (anekin007)
drivers side= 54 foot lbs,
rear tranny mount= 43 foot lbs,
top tranny mount= 54 foot lbs,
the nut on the end of the ac mount and the front trannt mount= 43 foot lbs,
Old Feb 1, 2005 | 09:06 PM
anekin007's Avatar
Default Re: Motor Mount Torque Specs for 99-00 si? (monicle)
Thanks for info
i just got the mm inserts today.. hopely i can get it in tomorrow
Old Feb 1, 2005 | 09:12 PM
Kamin's Avatar
there is a specific order too, i dont know it off the top of my head but its kinda important you torque it in order.
Old Feb 2, 2005 | 06:46 AM
monicle's Avatar
Default Re: Motor Mount Torque Specs for 99-00 si? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">there is a specific order too, i dont know it off the top of my head but its kinda important you torque it in order. </TD></TR></TABLE>
theres only an order to tightnen bolts and nuts that hold the brackets to the motor. If you dont remove the motor mount brackts then you dont need to worry about it.
Old Feb 2, 2005 | 08:23 AM
CardDealer's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">
theres only an order to tightnen bolts and nuts that hold the brackets to the motor. If you dont remove the motor mount brackts then you dont need to worry about it.</TD></TR></TABLE>
My helms shows a tightening order for the bolts attaching the bracket to the body.
Old Feb 2, 2005 | 11:00 AM
monicle's Avatar
Default Re: Motor Mount Torque Specs for 99-00 si? (schlit)
right but all he needs to do if hes doing inserts is take out the support bolt raise/lower, pop in the insert, and put it back through.
GsRrrr
Jan 5, 2011 10:27 PM
redsidriver
13
Mar 22, 2009 10:19 AM
skata89
Apr 27, 2006 05:15 PM
wernhersey
Mar 16, 2006 10:14 AM
