Garrett/Manifold/Downpipe B Series Setup
I have a Garrett T28 turbo along with a Revhard cast manifold and 3'' Mandrel bent downpipe.
Turbo
It is a Garrett T28 that is in PERFECT shape. It is internally gated and has no lag time at all, whenever you want boost just push down the throttle. Comes with the 3/4" return fitting already attached. Always allowed to cool down before I shut my car off. The fins are not chipped at all and the fins have never touched the housing in any place. Turbo has the bung for the o2 sensor built into it. Both oil and watercooled but I only ran oil. A/R is .80
Manifold
Like I said it is a cast piece not a tubular. There isnt a single crack in the whole entire thing and it is in immaculate shape. It is already tapped for an EGT gauge sending unit but if you are not going to run one you can always just plug it up.
Downpipe
I had it custom made here in town and it is SEXY. 3" from the turbo not little then flaring out to 3". It is all mandrel and is the same diameter clear to the exhaust connecting point. Clears the cross member in a CRX with a B18 so I'm positive you can use it in any car. Paid $275 for this thing alone!!!!!
Reason for selling
You probably think that it is junk and just dont want anything to do with it, truth is I got AEM EMS and now that my tuning capabilites are endless I got a giant ported and clipped 20g and had a custom manifold made. This setup on my LS in my CRX made 230tq/235hp on only 8 psi, have the chart to prove it. I guarantee you this thing operates flawlessly and boosts hard, if you have ANY picture that you want to see inparticular I will take it and send it to you if I do not have it already.
If you are interested in it at all hit me up and I will send you all the pics and answer any questions you may have.
Asking $800 plus actual shipping to your door. I will accept personal or cashiers checks or a money order.
Thanks
Josh Smith
Turbo
Manifold
Downpipe
Reason for selling
Thanks
Josh Smith
MAFDARK
Sep 1, 2006 12:23 PM
