engine bogging down
Old Jan 31, 2005 | 07:21 PM
99 honda civic's Avatar
Default engine bogging down
any one know what would be wrong when u push the gas and it bogs down until it hits 3000 RPM's?could it be bad fuses or spark plugs ? or just the timing
Old Jan 31, 2005 | 07:56 PM
eK9aT10pSi's Avatar
Default Re: engine bogging down (99 honda civic)
i have the same issue right now, thoguht it was the clutch but it could the the timing belt hopped a tooth or more ...
Old Jan 31, 2005 | 08:29 PM
rocketfuelcerx's Avatar
It might be something minor like fuses, spark plugs or fuel filter and/or(water in gas somehow), or distributor/wires but if it is a JDM ecu then it is likely the Ecu...
Old Jan 31, 2005 | 08:34 PM
Slopoke's Avatar
Default Re: engine bogging down (rocketfuelcerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocketfuelcerx &raquo;</TD></TR><TR><TD CLASS="quote">It might be something minor like fuses, spark plugs or fuel filter and/or(water in gas somehow), or distributor/wires but if it is a JDM ecu then it is likely the Ecu...</TD></TR></TABLE>
That is the dumbest thing I've ever read. Assuming the ecu is at fault because it is jdm??
Your problem could be a number of things. I would check out the simple things like spark plugs and wires first. My '90 civic used to stumble quite badly(at low rpm) because of faulty sparkplug wires. I replaced them, and the problem went away.
Old Jan 31, 2005 | 09:11 PM
shipping of Japenese (from Japan, you know across seas through middlemen from junkyards) this is how Ecu could be damged, is this not a rational presumption? I dygress.....
If your Ecu is chipped, that also may be to blame, if it was done half fast, it happened to me, the POS was from Japan and chipped...just trying to help
Old Jan 31, 2005 | 09:18 PM
eg4usdm's Avatar
well what are you running? is it the b16 or d series motor? either/or what mods are done if any. cause my civic bogs too but its just cause its a slow sohc, i have intake, exhaust and short throw. ya know
Old Feb 1, 2005 | 03:05 PM
Contraband's Avatar
Damn, some of these trial users. Its a shame really, almost embarrassing. I really dont think it has anything to do with the ecu. From my recolection, i replaced my plug wires and the sputtering stopped. If this doesnt work rebuild the distributor. ie new pick-up, coil, etc.
Ohh yeah, check the gap on the plugs too dawg, most plugs are already pre-gapped but you never know.
Old Feb 1, 2005 | 03:13 PM
civiccpedx's Avatar
Default Re: (LS95eg)
yeh mine was sputtering because i had cheap aftermarket wires on, switched back to OEM and it went away. Then a few days later, it came back, then i replaced the spark plugs and so far it has been gone. I think i have a oil leak that is breaking the connection between the wire and the plug.
MyEfSi2Slow
Mar 9, 2008 06:42 PM
yarara0825
Jan 4, 2008 04:44 PM
dustinO
Oct 4, 2006 01:50 PM
whitecrx
May 9, 2005 05:28 PM
BaNned
Jun 24, 2004 10:15 AM
