b20a3 compatable b20b?
Old Jan 31, 2005 | 07:17 PM
Tofu94's Avatar
Default b20a3 compatable b20b?
i have a b20a3,are the internals like,pistons,rods and caps the same? if yes or no what differance would it make? could i put b20b pistons and rods on the b20a3 crank?and is a gsr head a possible bolt on to that a3? need help asap...also could i put it in my 92 civc? if so what mounts should i use?
Modified by Tofu94 at 8:33 PM 1/31/2005
Old Jan 31, 2005 | 07:21 PM
mmuller's Avatar
Mad Scientist
Default Re: b20a3 compatable b20b? (Tofu94)
b20a from a prelude? if so no
Old Feb 1, 2005 | 04:32 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tofu94 &raquo;</TD></TR><TR><TD CLASS="quote">i have a b20a3,are the internals like,pistons,rods and caps the same? if yes or no what differance would it make? could i put b20b pistons and rods on the b20a3 crank?and is a gsr head a possible bolt on to that a3? need help asap...also could i put it in my 92 civc? if so what mounts should i use?
Modified by Tofu94 at 8:33 PM 1/31/2005</TD></TR></TABLE>
Don't even think about swapping that B20A3 into a 1992 Civic. It would require extensive custom fabrication. And it's not that great of a motor to begin with. Not worth it.
JDM_EK4_Coupe
10
Jun 29, 2007 12:54 PM
04element
Jun 15, 2006 05:53 AM
boostmywankle
May 4, 2006 11:49 PM
89JDMcrx
Oct 26, 2003 05:43 AM
