having a problem someone help?
Old Jan 31, 2005 | 06:12 PM
sittinlow4life's Avatar
Default having a problem someone help?
i have a 91 lx 4 door stock motor but have a crx hf trans that was built for race as the kid says first how can i tell what type of trans it is to see if it came from a hf ? or how can i fix the problem of it chewing up every axle put in it ? 3rd option i have 1000 dollar to to fix this motor or put to a swap any suggestions?
Old Jan 31, 2005 | 06:38 PM
thatbluecrx's Avatar
Default Re: having a problem someone help? (sittinlow4life)
b16
Old Jan 31, 2005 | 06:41 PM
crxtreme89h's Avatar
If you've already got $1k then you've got a good head start on getting a B16 swap. I'd say save up a G more and you're set.
Old Feb 1, 2005 | 04:17 AM
Default Re: having a problem someone help? (crxtreme89h)
well i would love to save another g and do that swap but need to get the car running rite asap ...........what can i do for a g to get it running rite again|?
Old Feb 1, 2005 | 04:24 AM
thumbtack's Avatar
is your problem that the tranny is breaking axles? or that the engine is shot? you need to be more specific. When posting you have a problem, it helps to state the problem.... Anyway if it is the tranny, go check out local junkyards for a tranny... there are plenty. you can get a used one from a pick-n-pull yard for around 50-75 bucks.
If you engine is shot, and you dont have enough for a b swap, just get a d-series... like 400-750$ depending on where you go and how much for shipping.
good luck
rexracerboy
134
Jul 16, 2010 05:32 PM
xlusiveracer
Feb 27, 2007 07:08 PM
davidcrx89
Feb 27, 2005 03:16 AM
juicy.koreans.suck
Mar 21, 2002 04:36 PM
