D-series Flywheel ?
Ive searched and not found any info..
I need to know if a D15B8 (CX) flywheel will work on a D16Z6 (Si). I need a new clutch for my Z6 and figured Id have my old CX flywheel turned in advance so I can just slap it together. So I need a definate answer. Thanks in Advance
Thanks for the quick answers... How reliable/safe would a lightened and balanced OEM flywheel be? Just trying to see if it will be worth it to ask the machine shop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLowCrx »</TD></TR><TR><TD CLASS="quote">How much does the OEM flywheel weigh stock? I was thinking a D-series only weighs about 12lbs stock...
wishful thinking!! stock d-series is about 17.5-18lbs (same as b-series), JDM ETi is about 15.8lbs (ITR which will not work is about 15lbs- simply stock unit shaved and balanced)
12lbs is pretty safe for NA applications under 180whp, as longest its done and its fully balanced
one of my old b-series flywheels shaved
</TD></TR></TABLE>wishful thinking!! stock d-series is about 17.5-18lbs (same as b-series), JDM ETi is about 15.8lbs (ITR which will not work is about 15lbs- simply stock unit shaved and balanced)
