Cluch petel not pushing back
Old Jan 31, 2005 | 05:43 PM
ewn1603's Avatar
Default Cluch petel not pushing back
Hey, this morning my cluch wouldn't engage. when I put it in nutral it started if I had the pedle pushed down but it didn't engage it and the pedle would stay down. I filled the master cylinger with break fluid, but it doesn't work. can anyone help me with this?
Old Jan 31, 2005 | 05:44 PM
eK9aT10pSi's Avatar
Default Re: Cluch petel not pushing back (ewn1603)
how long has it been since you bled your clutch slave cylinder ?
Old Jan 31, 2005 | 05:45 PM
ewn1603's Avatar
Default Re: Cluch petel not pushing back (eK9aT10pSi)
just bought it this summer and I haven't
Old Jan 31, 2005 | 05:59 PM
ewn1603's Avatar
bump
Old Jan 31, 2005 | 06:02 PM
gsr18cx's Avatar
bleed it, check for leaks......or replace master cylinder.
Old Jan 31, 2005 | 06:05 PM
ewn1603's Avatar
Default Re: Cluch petel not pushing back (gsr18cx)
I can't bleed it because the cylinder is totally engaged and there is no pressure on the cluch pedle.
Old Jan 31, 2005 | 06:11 PM
ewn1603's Avatar
bump it up!
Old Jan 31, 2005 | 06:14 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ewn1603 &raquo;</TD></TR><TR><TD CLASS="quote">I can't bleed it because the cylinder is totally engaged and there is no pressure on the cluch pedle.
the point of bleeding is to get all the air out. Which gives you "pressure" back on the petal
Old Jan 31, 2005 | 06:15 PM
ralphie14's Avatar
Default Re: Cluch petel not pushing back (BlueHatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">
the point of bleeding is to get all the air out. Which gives you "pressure" back on the petal</TD></TR></TABLE>
yup but you will need a friend it is a 2 person job.
Old Jan 31, 2005 | 06:16 PM
ewn1603's Avatar
Default Re: Cluch petel not pushing back (ralphie14)
what exactly do I have to do?
like how do I get it started?
Old Jan 31, 2005 | 06:30 PM
T4eg's Avatar
make sure the reservoir is toped off with fluid and put the cap back on. Then pump the clutch petal and hold it down. Then loosen the bleed on the slave cylinder (on the trans with 8mm wrench) then tightn it back (snug) then release clutch petal. Then pump up again and repeat the process. Make sure that u check the fluid level and keep it topd off
chris
Old Jan 31, 2005 | 06:32 PM
ewn1603's Avatar
ok, thanks for that but the main problem is that the clutch pedle doesn't popl back out. I push it in, it goes in easier than normal then it stays down. it doesn't push back up. so if I wanted to go out and bleed the cluch right now I couldn't because the cluch is pushed then it stays down. that's the main problem
Old Jan 31, 2005 | 06:37 PM
ralphie14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ewn1603 &raquo;</TD></TR><TR><TD CLASS="quote">ok, thanks for that but the main problem is that the clutch pedle doesn't popl back out. I push it in, it goes in easier than normal then it stays down. it doesn't push back up. so if I wanted to go out and bleed the cluch right now I couldn't because the cluch is pushed then it stays down. that's the main problem</TD></TR></TABLE>
Um yeah we know you will have to use this thing called you hand to pull it up a few times while building pressure.
Old Jan 31, 2005 | 06:38 PM
ewn1603's Avatar
fairenough, what happens if it doesn't build up pressure?
Old Jan 31, 2005 | 06:41 PM
T4eg's Avatar
just go call a friend over that u trust to push the petal in and out then have him hold it while u break the bleeder. DO this atleast 5-6 times you SHOULD get a petal back. Once u try that come back
Chris
ralphie14's Avatar
If is doesn't build pressure I would say you have either a bad master or slave cylinder that happened to my roommate last summer in his hatch. He replaced both of them and has not had a problem since.
Old Jan 31, 2005 | 06:52 PM
ewn1603's Avatar
Sweet!
I'll talk to ya tomorrow then eh
Old Jan 31, 2005 | 06:55 PM
red_hatchback's Avatar
bleed it
Old Feb 2, 2005 | 07:43 PM
ewn1603's Avatar
So I blead the cluch, it works fine, thanks all for advice. But should I still replace the master and slave cylinder???
Old Feb 3, 2005 | 11:43 AM
clint g's Avatar
Not if its not giving you a problem I replaced my slave cylinder and the pedal sticks on the way back but its not really a problem
Old Feb 3, 2005 | 12:35 PM
boostedcivicsir's Avatar
Mr. Badwrench
you need to replace the either the master or the slave. look under the steering wheel where the pedals are. see if there is any fluid leaking where the clutch rod goes through the fire wall. if there is you need to replace the master. and do the same with the slave. peel the boot back and see if there is fluid leaking out of it. if there is, replace that. make sure you get the correct adjustment on the master if you replace it. you should have 1/2 - 3/4 of free travel on the pedal before it starts to engage.
Old Feb 3, 2005 | 12:59 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ewn1603 &raquo;</TD></TR><TR><TD CLASS="quote">So I blead the cluch, it works fine, thanks all for advice. But should I still replace the master and slave cylinder???
If it works fine, and you have pressure in the pedal back; then no, your cylinders are fine. You just had air in the system.
Old Feb 3, 2005 | 02:15 PM
93CivicSI's Avatar
check behind the carpet on the inside of your firewall and make sure the clutch master cylinder is not leaking, if it is, buy a new one.
Old Feb 3, 2005 | 07:35 PM
AutoXer's Avatar
Default Re: Cluch petel not pushing back (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI &raquo;</TD></TR><TR><TD CLASS="quote">check behind the carpet on the inside of your firewall and make sure the clutch master cylinder is not leaking, if it is, buy a new one.</TD></TR></TABLE>
Yeah, that is true... I should have put that it would be okay if there were no signs of a leak.
Jay Dirt
Oct 26, 2007 05:27 PM
LSEGHATCH
Jun 11, 2006 11:04 AM
LCDeuce
Feb 9, 2005 11:14 AM
98 blacksh
Jan 10, 2005 03:45 AM
LSTEG96
Sep 23, 2003 12:18 PM
