Upgrading 96 spec Non-HID to 98 spec HID?
Old Jan 31, 2005 | 05:25 PM
mojo_jojo's Avatar
Default Upgrading 96 spec Non-HID to 98 spec HID?
Hello,
I have a 96 spec non-abs model JDM ITR. I have the chance of picking up a pair of 98 spec jdm HID headlights. Are the 98 spec ITR HID headlights plug and play with the 96 spec ITR, or is there any kind of special hardware I will need to make the upgrade? I want to stay as oem as possible.
thanks
Old Jan 31, 2005 | 06:22 PM
mojo_jojo's Avatar
Default Re: Upgrading 96 spec Non-HID to 98 spec HID? (mojo_jojo)
are the JDM 98 spec oem HID headlights plug and play with the JDM 96 spec non-abs ITR?
Old Jan 31, 2005 | 09:20 PM
mojo_jojo's Avatar
anybody?
Old Jan 31, 2005 | 11:40 PM
Naruto's Avatar
It should be plug and play ( well...for me it was ), but do a search for the wiring diagram for the harness just for safety's sake.
Old Feb 3, 2005 | 05:00 AM
mojo_jojo's Avatar
Default Re: Upgrading 96 spec Non-HID to 98 spec HID? (psychoticmindset)
anyone else to back this up?
Old Feb 3, 2005 | 05:57 AM
MUGEN2PT2's Avatar
There plug and play,...however I think the switch was up-graded.
Old Feb 3, 2005 | 07:47 AM
dnatrance's Avatar
Default Re: Upgrading 96 spec Non-HID to 98 spec HID? (MUGEN2PT2)
I dont know about the switch, but I do know they plug right in. Now you will have to get a windsheild washer fluid tank from a type R with HIDs. The ballast sits to far back on the driver side and interferes with the filler tube.
Old Feb 3, 2005 | 08:07 AM
jdmspoonitr's Avatar
Default Re: Upgrading 96 spec Non-HID to 98 spec HID? (dnatrance)
Correct. In a non-abs ITR they are plug n play. If you had ABS u would have to switch to the smaller 98 spec ABS.
Old Feb 3, 2005 | 08:24 AM
Black R's Avatar
25 Year Member
Default Re: Upgrading 96 spec Non-HID to 98 spec HID? (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">Correct. In a non-abs ITR they are plug n play. If you had ABS u would have to switch to the smaller 98 spec ABS.</TD></TR></TABLE>
.....what about usdm cars with abs and jdm front end?
Old Feb 3, 2005 | 10:55 AM
DC2 to AP2's Avatar
Default Re: Upgrading 96 spec Non-HID to 98 spec HID? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
.....what about usdm cars with abs and jdm front end?</TD></TR></TABLE>
94-97 have a bigger abs module which the hid ballast hits/rubs/touches it. 4 options to get around this. 1. bend the hardlines alittle 2. relocate the ballast 3. change to 98+ abs unit 4. just get rid of the abs all together.
MUGEN2PT2: which switch are you talking bout?
Old Feb 4, 2005 | 02:32 PM
mojo_jojo's Avatar
Default Re: Upgrading 96 spec Non-HID to 98 spec HID? (imola-red dc2)
thanks for all your guys help
Old Feb 4, 2005 | 02:35 PM
808dc2's Avatar
I anyone needs the 98 spec jdm itr windshield washer fluid bottle for the HID conversion, go <u>here</u>
Old Feb 5, 2005 | 04:09 PM
mojo_jojo's Avatar
well I plugged the oem hid's into my 96 spec non-hid headlight harness and NO HID. Only the fog lights and city lights turn on. I have no power to the low beam HID lights and high lights. So these are <u>not</u> plug and play with the 96 spec heaglights harness. It seems the wire pattern in the connector is different. It seems I may need to add another wire to my 96 spec harness for the HID low beams to work. I have only 4 wires connecting to the male end connector and I'm pretty sure the 98 spec HID headlight male end connector has 5 wires connecting to it(5th for HID low beam current).
**Please help**
Is there anything I can do to make the hid work with out having to rewire anything? I'm clueless when it comes to wiring.
I also have the extra plug from the holagen lowbeam just hanging since it has no place to plug into on the OEM HID headlights. Could this still be used?
thanks
Old Feb 5, 2005 | 05:14 PM
nugen power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnatrance &raquo;</TD></TR><TR><TD CLASS="quote">I dont know about the switch, but I do know they plug right in. Now you will have to get a windsheild washer fluid tank from a type R with HIDs. The ballast sits to far back on the driver side and interferes with the filler tube.</TD></TR></TABLE>
Is this true???
now if i do an jdm front end conversion on a usdm typeR will i need this washer tank?
ps&gt;&gt;sorry to cut in on your thread man
Old Feb 5, 2005 | 05:25 PM
mojo_jojo's Avatar
Default Re: Upgrading 96 spec Non-HID to 98 spec HID? (nugen power)
yes you will if you want to keep your windshield washer fluid bottle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808dc2 &raquo;</TD></TR><TR><TD CLASS="quote">I anyone needs the 98 spec jdm itr windshield washer fluid bottle for the HID conversion, go <u>here</u></TD></TR></TABLE>
Kanekz13
Jan 26, 2012 08:28 PM
Rishiras
May 18, 2008 04:30 PM
mojo_jojo
Feb 7, 2005 10:36 PM
gingboy
Aug 2, 2002 09:30 PM
JDM DC2 R
Feb 24, 2002 01:15 PM
