IACV.. can you adjust??
Old Jan 31, 2005 | 04:21 PM
AlxSiR7's Avatar
Default IACV.. can you adjust??
I just got my intake parts back together & I got the idle set back down to around 900rpms (as low as I can get it via trottle body screw).. so I looked at the IACV & noticed a hex key hole (I think it's a hex key.. it's 5 sided).. does anyone know if I can adjust the idle that way??
Old Jan 31, 2005 | 06:40 PM
AlxSiR7's Avatar
Default Re: IACV.. can you adjust?? (AlxSiR7)
lets not all reply at once.. guess no one knows
Old Jan 31, 2005 | 06:47 PM
Old_Honda's Avatar
No, the only way to manually adjust idle is the screw on the throttle body. Did you unplug the IACV before adjusting the screw?
Old Feb 1, 2005 | 05:06 AM
AlxSiR7's Avatar
Default Re: IACV.. can you adjust?? (OldGSR)
when i unplug the iacv the idle is supposed to drop to 450 or so when the car is warmed up.. but it only drops to normal idle ~750 when i unplug it.. and thats with the tb screw tightened all the way.. when i plug the iacv back in my idle is back up to 900-1000
Old Feb 1, 2005 | 06:39 AM
dnatrance's Avatar
Did you get gaskets when you took your intake manifold apart? You can use the old ones, but they are prone to leak. Also if you did change them, I have seen a lot of people leave a small sliver of old gasket on there... that will also cause a leak.
Throttle body gasket too, make sure you change that one if you have taken it off
Old Feb 1, 2005 | 07:08 AM
AlxSiR7's Avatar
Default Re: IACV.. can you adjust?? (dnatrance)
all new gaskets
Old Feb 1, 2005 | 10:02 AM
Old_Honda's Avatar
maybe your fast idle thermovalve isn't closing all the way.
Old Feb 1, 2005 | 10:12 AM
AlxSiR7's Avatar
i tightened it already
Old Feb 1, 2005 | 10:13 AM
NathanMorris's Avatar
what did you do to the intake system, that might help us figure it out.
- Nathan
Old Feb 1, 2005 | 10:14 AM
Old_Honda's Avatar
i mean the diaphragm inside it, it could be not closing all the way.
Old Feb 1, 2005 | 10:24 AM
AlxSiR7's Avatar
Default Re: IACV.. can you adjust?? (92Lx)
took off iacv, cleaned it, took off tb to get the fitv off, clean both of them and tightened the fitv. put new tb gasket on and got everything back together.
Old Feb 1, 2005 | 11:23 AM
IVI's Avatar
IVI
by the way thats not a hex screw, and has nothing to do with adjusting idle.
Old Feb 1, 2005 | 11:42 AM
AlxSiR7's Avatar
Default Re: IACV.. can you adjust?? (IVI)
yea.. its 5 sided.. so penta screw.. whatever. so nothing to do with idle? what does it do then??
thewrai6th
Oct 28, 2018 05:32 PM
james007
Apr 30, 2010 04:26 PM
sik_sol
Aug 18, 2006 02:08 PM
steve_s
Jan 22, 2003 02:06 AM
