Oil on my spark plugs....is this a problem?
I changed out my old spark plugs with stock NGK plugs. My car has about 61k miles on it. I noticed that there was little oil (very little, equivalent to a drop or two) around the shaft of the plug. I was wondering if this was anything to be concerned.
One more thing, my engine is stock. The oil was only found on plugs #1 and #4.
[Modified by Fooman, 7:08 PM 1/14/2002]
It came from your spark plug tube seals. It is not really a problem yet but I would recommend you replace your valve cover gasket when you do your timing belt at 90k. Make sure you use some Hondabond on the tube seal gaskets.
professorman
Feb 19, 2003 07:27 AM
