RSX OEM 16" wheel offset?? And what should 17" wheels offset be??
I just want to know what the offset is on my stock 16" wheels, and then also what are ok offsets for 17" wheels and also 18" wheels. I'm not sure if the # should increase decrease, or stay the same. Thanks for help.
stock is 45. If you get 17's, it depends on the look. going with a lower number will have the wheel sit farther out and with a higher number, it'll do the opposite. With 17's, a 45-42 offset will work. With 18's, some people go with 48 depending on how wide the wheels is and tire size. Good luck.
Shawn
14
Feb 9, 2004 01:30 PM
sk898
Dec 18, 2002 02:22 PM
MikeD
Jul 24, 2001 09:05 AM
