FRONT LEFT RIMS VIBRATING
Old Jan 31, 2005 | 11:06 AM
crxsi541's Avatar
Default FRONT LEFT RIMS VIBRATING
does anyone know why my front left rims starts to shake after about 50-60 and kinda is back to normal around 70? some one was telling me the rims prolly bent.. the car isnt lowered......
Old Jan 31, 2005 | 12:21 PM
RACINTWEEK's Avatar
Default Re: FRONT LEFT RIMS VIBRATING (crxsi541)
you need to balance your tires or get an alignment if its only at high speeds
if you notice it when braking hard you prob have a bent wheel or bad tie rod ends
Old Jan 31, 2005 | 03:50 PM
crxsi541's Avatar
Default Re: FRONT LEFT RIMS VIBRATING (RACINTWEEK)
thanks alot man
Old Jan 31, 2005 | 03:59 PM
drdisco69's Avatar
It could be a shifted belt in the tire as well. My wheels are perfectly balanced, but can give a little shake at (very) high speeds. Since yours is in a limited range, I'd say balance it.
Old Jan 31, 2005 | 05:21 PM
EmidnightF's Avatar
Default Re: FRONT LEFT RIMS VIBRATING (drdisco69)
check your lug nuts. i know that sounds dumb but make sure there completely torqued down to specs. i know some people that have forgot to do that and it starts vibrating.
Old Jan 31, 2005 | 06:17 PM
Kwicko's Avatar
Default Re: FRONT LEFT RIMS VIBRATING (EmidnightF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EmidnightF &raquo;</TD></TR><TR><TD CLASS="quote">check your lug nuts. i know some people that have forgot to do that and it starts vibrating. </TD></TR></TABLE>
I'm one of them. Yup, I've worked on my car and then driven off to test it out, only to find out a block later that I hadn't tightened the lugnuts. If that were the problem in his case, though, I think he'd find out rather quickly at 50-60mph! Seriously, when I did it, I went less than one block at less than 30mph, and by the time I realized there was a problem and got stopped, three of the four nuts were amost halfway off. Bad feeling, that. Makes you feel like a dolt, too.
Most likely it's a wheel out of balance. If you've got time, try swapping the rear tire on that side for the front one, and see what it does. If it's an unbalanced wheel, you should feel it on the rear of the car now.
Mike
Old Jan 31, 2005 | 07:29 PM
crxsi541's Avatar
Default Re: FRONT LEFT RIMS VIBRATING (Kwicko)
thanks alot everyone.
low_and_slow
Apr 25, 2010 08:51 AM
ukkb920
Jun 12, 2007 10:38 AM
Johnytang
Aug 24, 2004 08:51 PM
Louie_EM1
May 30, 2004 10:31 PM
OoCRXoO
15
May 15, 2003 09:20 AM
