Honda Techinicians, Car wont start need guidance
Old Jan 31, 2005 | 10:56 AM
Mark D. Surface's Avatar
Default Honda Techinicians, Car wont start need guidance
It started here.... https://honda-tech.com/zerothread?id=1121792
So now I have changed the fuel filter, cap, rotor, plugs. Timing belt is still in place.
When you turn the ignition over the engine just fires, kinda fast. Fuel pump does come on and the ECU does not flash any codes. What could be the problem?
Old Jan 31, 2005 | 11:04 AM
nucivowner's Avatar
Default Re: Honda Techinicians, Car wont start need guidance (Mark D. Surface)
you may have a valve that is stuck upen. that would make the motor turn over really fast. its caused by a loss of compresion
Old Jan 31, 2005 | 12:15 PM
crxtreme89h's Avatar
Check your ignition switch (AKA ignition starter switch). My symptoms were that I could start "turn over" the car for one second, but it would immediately die after I let go of the key. If I wiggled/shook the key in the ignition I could sometimes get it to start and stay running. Replaced Ignition switch and the car started right up. Ignition switch took me about 20 minutes to replace in the dark. Cost was $78 plus tax at Checker Auto Parts.
djfrankdatank
Sep 23, 2014 09:05 PM
jacobsd1904
Feb 24, 2011 01:18 PM
prelude504
Sep 7, 2009 03:19 PM
88 EF Hatch
Jun 27, 2009 06:52 PM
91hob20hb
Jul 17, 2004 11:16 AM
