Different crankshaft pulleys for D15?
Old Jan 31, 2005 | 08:46 AM
Lsos's Avatar
Default Different crankshaft pulleys for D15?
I just got a replacement D15 for my crx. As such, I had to take parts (alternator, transmission, flywheel, crank pulley, etc.) off of the old D15 and put them on the new. Come to find out...the crank pulley doesn't fit on the new engine. There's straight up about an 1/8" of play between the pulley and the shaft.
Does anybody know the story with this? The engine codes are the same, so it seems weird to me that the crankshaft would be a different diameter.
Old Feb 1, 2005 | 04:56 AM
Lsos's Avatar
Default Re: Different crankshaft pulleys for D15? (Lsos)
Well, I think I figured it out myself. The engine is from 1988, and apparently 1988 engines had a different pulley and a smaller bolt (12mm). Can anyone confirm this?
Old Feb 1, 2005 | 07:16 AM
jlicrx's Avatar
true - 88 DX and Si (have also seen on some 89s) had smaller 22mm front crankshaft snout - later ones were 24mm
york
Aug 5, 2015 04:22 PM
thehatchninja
Jul 13, 2008 10:04 PM
91zSi
Dec 26, 2005 03:31 PM
Tyson
35
Dec 30, 2004 03:06 PM
bulori
Apr 22, 2002 06:27 PM
