just got paid-want to do the OBd1 swap, help me make the list!
Old Jan 31, 2005 | 07:54 AM
FakeJDMEF8's Avatar
Default just got paid-want to do the OBd1 swap, help me make the list!
so i have plenty of money to spend and want to make my 90 CRX Si obd1 (Has a B16a) what parts do i need to start looking for and for about how much ($$$$) used and new. thanks guys.
think a VAFCII would be worth $300.00 installed??? im debating it.
Old Jan 31, 2005 | 07:55 AM
PHOBIA's Avatar
not with out any real mods would the vafc controller really do anything.but if you do get one get it tuned from a shop.dont just throw it in and start screwing with it because you will have a lot of problems later.
Old Jan 31, 2005 | 07:58 AM
EP3_05's Avatar
Default Re: just got paid-want to do the OBd1 swap, help me make the list! (FakeJDMEF8)
For an OBD1 conversion you need:
OBD0-OBD1 conversion harness
OBD1 ecu
4 wire heated O2 sensor
OBD1 B series distributor
Old Jan 31, 2005 | 09:20 AM
kyle-5953's Avatar
Default Re: just got paid-want to do the OBd1 swap, help me make the list! (91civic)
the 4 wire heated o2 isn't necessary, if you're doing the swap you might as well chip the ecu and run uberdata or similar and in those programs you can disable o2 heater. plus most conversion harnesses that I've seen don't even give you the wires for o2 heater.
also, make sure you get the b-series distributor, I tried ghetto rigging a d-series one and it doesn't line up right when you cut off the leg you think needs to get chopped, the car won't even start.
91lsturbocrx
Jan 29, 2009 12:01 PM
dem0nk1d
Aug 8, 2007 02:17 PM
mrx
Mar 12, 2005 01:06 PM
EVOCELICA
Jul 9, 2004 01:10 PM
EFing8
11
Dec 15, 2002 09:08 AM
