Speedometer jumping after LS swap. Help anyone?
Old Jan 31, 2005 | 07:52 AM
eg6_rick's Avatar
Default Speedometer jumping after LS swap. Help anyone?
After i swapped an OB2 LS into my 93 Hatch, sometimes when i'm driving over 60mph the speedometer jumps up and down. I was thinking maybe because of the speed sensor or wiring- since i was using 94 integra GSR wiring hardness for the swap to make it simple. But i just wanted to make sure. Anyone know what else can be causing speed to jump?
Modified by eg6_rick at 11:29 AM 2/1/2005
Old Feb 1, 2005 | 10:31 AM
eg6_rick's Avatar
Default Re: Speedometer jumping after LS swap. Help anyone? (eg6_rick)
bump
Old Feb 1, 2005 | 10:55 AM
notstock93's Avatar
Sounds like the VSS is going nuts, check the wiring. I thought VSS threw a code if it was out, though.
usdm07
Aug 10, 2010 11:06 AM
Silspeg6
Mar 17, 2008 10:42 PM
