Turbo Type-R Spark Plugs.
Old Jan 31, 2005 | 07:52 AM
200cs's Avatar
Default Turbo Type-R Spark Plugs.
I am about to complete my T3/T4 install and would like information about cooler plugs-several choices would be nice. Anybody got info? How about part numbers? Thanks in advance for your time.
Old Jan 31, 2005 | 08:03 AM
DC2R714's Avatar
Default Re: Turbo Type-R Spark Plugs. (200cs)
NGK BKR7E's or 8 series if you are making more than 350-400whp.
Old Jan 31, 2005 | 08:09 AM
FOrSfEd's Avatar
Default Re: Turbo Type-R Spark Plugs. (DC2R714)
NGK BKR7E's Is what I am running gapped at .30
Old Jan 31, 2005 | 10:35 AM
BoostR41's Avatar
Default Re: Turbo Type-R Spark Plugs. (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">NGK BKR7E's Is what I am running gapped at .30</TD></TR></TABLE>
same cept mine are gapped at .22
Old Jan 31, 2005 | 12:28 PM
Haleiwa-Brando's Avatar
Default Re: Turbo Type-R Spark Plugs. (BoostR41)
Mine are Denso's. Gapped to .30
Old Jan 31, 2005 | 12:39 PM
PM-Performance's Avatar
Default Re: Turbo Type-R Spark Plugs. (Haleiwa-Brando)
I ran the NGK's as listed above. I ran the 7's upto 400whp. then swapped in for 8's jsut for piece of mind and had 9's for race fuel /hi boost that i never got to use
Old Jan 31, 2005 | 01:39 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">NGK BKR7E's </TD></TR></TABLE>
mine are gapped to .028. My tuner recommended .028 - 0.32.
This is the right plug, you can't go wrong. Higher power you might want to consider 8's or higher like the others said.
[Edit, if you search the Forced Induction forum archives you'll get a lot of hits.]
-Chris
Old Jan 31, 2005 | 03:05 PM
Dr Pooface's Avatar
Old Jan 31, 2005 | 04:12 PM
mugenracer's Avatar
HKS S40i's Heat range 8 and gapped to 0.8mm
Old Jan 31, 2005 | 04:40 PM
Finland's Avatar
same here.
u n v kenny
Aug 20, 2007 11:54 AM
Black R
May 11, 2005 05:30 PM
Ultra Jurassic
Apr 21, 2005 07:35 AM
JICB16B
44
Sep 26, 2003 07:34 AM
Vtec92Civic
Aug 23, 2003 07:00 AM
