How many of you are running stock rods in your B20vtec?
Just wondering if any of you have had any problems or not running the stock rods. I just had mine shotpeened and I'm running cr of 12.5-1. I haven't assembled the bottom end yet and I'm debating if these will be good for a max of 220 whp.
im running stock b20 rods, and i have 12.3:1 comp ratio, and i rev to 8900, my motor is darton sleeved, and has je pistons, and i have a itr head and toda spec b cams, my engine builder said the b20 rods will be fine as long as your not up there all the time . . . .
If you have to second guess yourself why not just buy some eagle rods for like $300 considering you plan to make 220whp its not worth the thousands of dollars your going to put into it if it blows from not spending 3 bills on rods, just a thought thats all.
thanks for the input, the only shitty thing is that I've already gotten my rods pressed onto the pistons, and the arp rod bolts installed and stretched. Just wondering if it's pretty common to see a rod snap in these setups or not
I currently use stock rods as well too. I used ARP rod bolt for good insurance and it is alway a good idea to fully balance the bottom end cause you will rev higher than the b20 is supossed to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype Vtec »</TD></TR><TR><TD CLASS="quote">do u need new piston bearings? if ur going forge pistons? </TD></TR></TABLE>Piston bearings? Do you mean wrist pins? If so, they should come complete with the piston sets you buy.
im going to run stock rods with arp rod bolts..im only reving to 8000, maybe 82-8400rpms. id rather stay in the 8K area. block is assembled just waiting on some loot to get a vtec water pump and OBD1 dizzy.
I run a CRVTEC setup in my CRX with the stock rods. The crank shaft was balanced and micropolished and I'm running aftermarket pistons with a stock ITR head. I keep the revs under 8K just for safety sake but so far I haven't had a problem with it. Makes awesome power, I was lucky enough to have a YS1 LSD tranny in it so launching with all the torque isn't as tricky as it might be with open diff setups.
Anyways, back on topic, I run stock rods and rod bolts. I have talked to several people about this to see if it would be a reliability issue. They all told me as long as I'm not constantly revving into the stratosphere that I'll be ok on stock rods/bolts. I have taken my car to 8200RPM a few times just for grins to see what it feels like, honestly I think its making the most power just a little before 8K rpms. So in my case I shift before then (usually about 7800). If you get some short gears you won't need to rev a CRVTEC setup to get fast times, the strength of this car lies in the fact that it builds power throughout the rev range much more effectively than smaller displacement Honda motors. Just my 2c.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20todaej6 »</TD></TR><TR><TD CLASS="quote">im running stock b20 rods, and i have 12.3:1 comp ratio, and i rev to 8900, my motor is darton sleeved, and has je pistons, and i have a itr head and toda spec b cams, my engine builder said the b20 rods will be fine as long as your not up there all the time . . . .</TD></TR></TABLE>
i swear why people even chance **** like that..if your stupid stock rod bolts orr something fail one dday and u put a hole through your block and **** up your head..your gonna really be happy u saved 300 dollars and wasted round a grand at least.... oh well
Matt8314
Apr 24, 2017 07:36 AM
desert eagle
10
Jan 28, 2004 07:21 PM
blackcruzan
10
Dec 25, 2003 01:42 PM
maybe that answered my question, anybody have some input, thanks
