zc running but very poorly
Old Jan 31, 2005 | 06:37 AM
evilsolb16's Avatar
Default zc running but very poorly
got the zc motor swap running kinda good but i think something may be alittle off. if first gear at like 4000 rpm it will back fire also if your just rev it up it ill back fire. in second, thrid gear if you floor it, the motor bogges down real bad, i changed pulges and wires, also shoot it with a timing gun, it showed it was right on the red mark on the crank pulley, could it be a vacume leak. any help would be great.
Old Jan 31, 2005 | 06:45 AM
EP3_05's Avatar
Default Re: zc running but very poorly (evilsolb16)
How about the cam timing? It could be off a tooth
Old Jan 31, 2005 | 06:48 AM
evilsolb16's Avatar
Default Re: zc running but very poorly (91civic)
possibly, i turned to motor over manuily and piston came to tdc, and cams were right on the marks. ill check when i get off work.
Old Jan 31, 2005 | 07:02 AM
daidilus's Avatar
any CELs? check your map sensor!
Old Jan 31, 2005 | 07:26 AM
evilsolb16's Avatar
Default Re: (daidilus)
code 4 and 14 i think thats it
Old Jan 31, 2005 | 09:07 AM
daidilus's Avatar
4 Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 85-98
CKP Sensor (Crankshaft Position Sensor)
defective circuit or unplugged / defective sensor
14 Accord Civic CRV CRX Del Sol Odyssey Prelude
88-98 88-98 97-98 88-91 93-97 95-98 88-98
IAC Valve (Idle Air Control)
last time i checked there was a 2 sensor difference in the ZC and the SOHCs
its_teddd
Jun 14, 2009 06:42 PM
bubba3369
Engine Management and Tuning
Jan 31, 2009 04:51 PM
westside49block
Feb 2, 2008 08:55 PM
Acid832
Aug 8, 2003 05:13 PM
ern
Jan 17, 2002 07:40 AM
