FS: Stanton Sk-6 2-channel DJ Mixer like new
Old Jan 31, 2005 | 04:05 AM
jmayhew's Avatar
Default FS: Stanton Sk-6 2-channel DJ Mixer like new
I got a "like new" stanton Sk-6 2-channel mixer for sale. $135..retails for $200
mint condition no scratches..only selling because i'm getting a new 3channel mixer.
It has mulitple input types so it can be used with turntables, CDJ's, stereos computers etc..
great starter mixer.
it also has reversable face plate so if you scratch it or stain it you can flip the plate to have a brand new face plate....its never been switched & there are no marks in the active side.
INFO: This battle mixer from Stanton has all the features that professional turntablists need. No other mixer in this class features an effects loop for external effects.
* Unique PROTEKT panel hides all screws underneath the top panel for smooth, hassle-free fader operation.
* Super smooth crossfader with photo-coupler system and curve adjustment
* Reverse function for crossfader and each channel fader with 2 color
* LED (green: normal, red: reverse)
* 2 line and 2 phono inputs.
* Gain and 2 band EQ (+9/-26dB) on each channel
* Effects send/return for external effects. Effects are post-crossfader.
* ON/OFF switch for each channel plus MIC.
* Three-way, 8 position line/phono toggle switches with FLASH feature (optional 2 way switch available separately)
* Mic input with volume control and 2 band EQ (+10/ -10 dB)
* Headphone input with volume control and cue pan fader
* Master output (TRS balanced 1/4" and unbalanced RCA)
* Transducers: 40mm drivers
* Frequency range: 3-28,000 Hz
* Sensitivity Impedance: 102 dB 50 Ohm
* Cable length: Approx. 8.5Ft (2.8m)
* Maximum power input: 80mW
* Jack (mm): 3.5mm stereo with 1/4" (6.3mm) adaptor
* Weight (w/o cord): Approx. .4 Lb (170g)
Old Jan 31, 2005 | 06:09 AM
jmayhew's Avatar
Default Re: FS: Stanton Sk-6 2-channel DJ Mixer like new (jmayhew)
bump
Old Feb 1, 2005 | 09:59 AM
jmayhew's Avatar
bump
Old Feb 4, 2005 | 04:54 AM
jmayhew's Avatar
$125 shipped
Simon Tibbett
Jul 11, 2011 01:57 AM
501hpintegra
Feb 5, 2007 02:13 PM
501hpintegra
