Question for those of you with Drag Radials.
What size are yours and what psi do you have them at the track.
I plan on getting some bfg dr's, 225 50 15's.
I'm thinking somewhere around 16-17 psi.
205/55/14 Nitto 555r drag radials on 14x5.5 HX wheels and I have run them as low as 12psi at the track without a problem. I was dropping the clutch from about 5500 rpms and I ended up pulling a 2.0 60 foot. I run them anywhere form 16-20psi on the streets.
Depends on your set-up...... looks like you have a H22A so I would think about your gears most H22 trannies are long geared so I would say 205/50's at 17psi if your all motor I ran those last year hit 2.0's and 1 1.9 with no traction bars no LSD. If you have turbo then get the 225's. I will be using 225's this year but I have short years...... just a thought. Rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer »</TD></TR><TR><TD CLASS="quote">Depends on your set-up...... looks like you have a H22A so I would think about your gears most H22 trannies are long geared so I would say 205/50's at 17psi if your all motor I ran those last year hit 2.0's and 1 1.9 with no traction bars no LSD. If you have turbo then get the 225's. I will be using 225's this year but I have short years...... just a thought. Rob</TD></TR></TABLE>
I running the m2b4 LSD tranny.
Here are the gear ratios
M2B4 (JDM LSD)
1. 3.307
2. 1.950
3. 1.360
4. 1.034
5. 0.787
FD 4.266
M2B4 (JDM LSD)
1. 3.307
2. 1.950
3. 1.360
4. 1.034
5. 0.787
FD 4.266
