JDM ITR interior pieces?
Old Jan 30, 2005 | 09:03 PM
eg6hatch's Avatar
Default JDM ITR interior pieces?
im sure this has been covered, but i cant find it, what all JDM ITR pieces will fit in usdm integras, as in will the shifter console, and teh climate control, new to tegs, help thanks, no gay comments please
Old Jan 30, 2005 | 09:13 PM
jdmspoonitr's Avatar
Default Re: JDM ITR interior pieces? (eg6hatch)
the only things that fit are the climate control, ash tray, cig lighter and surround piece. Everything else does not fit
Old Jan 30, 2005 | 09:14 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch &raquo;</TD></TR><TR><TD CLASS="quote">no gay comments please </TD></TR></TABLE>
well, it would behoove you not to post these sort of questions in the same manner, should you not want any "gay" comments.
and the reason your search was probably not conclusive is because everyone who's asked this question before probably used an equally ineffective topic.
the ashtray housing/cigarette will not fit in a usdm spec itr.
Old Jan 30, 2005 | 09:16 PM
Default Re: JDM ITR interior pieces? (255.255.255.255)
It will if u get the surround piece too
Old Jan 30, 2005 | 09:23 PM
penpen's Avatar
the 'cf' switches that go on doors for windows and mirrors etc. fit too, right?
Old Jan 30, 2005 | 09:24 PM
eg6hatch's Avatar
Default Re: JDM ITR interior pieces? (jdmspoonitr)
yeah i will trust spoonitr on this more than 255.255.255.255, just because he was actually cool enough to not be a smart ***, thanks spoonitr
Old Jan 30, 2005 | 09:35 PM
And yes the window switches will fit but you need to dremel a little bit.
Old Jan 30, 2005 | 09:36 PM
Actually maybe i should put it this way. Everything will fit except the driver and passenger side faux cf vent and the shifter console with the carbon shifter plate. Everything else should fit.
Old Jan 30, 2005 | 09:51 PM
penpen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah i will trust spoonitr on this more than 255.255.255.255, just because he was actually cool enough to not be a smart ***, thanks spoonitr </TD></TR></TABLE>
255.* wasn't being a smartass, he was just pointing out that if you're going to put a disclaimer up like that, you're asking for it.
he left his response to your question otherwise.
another tip: calling him or anyone in here names after you come in here asking a question isn't going to make you any friends
Old Jan 31, 2005 | 12:50 AM
eg6hatch's Avatar
Default Re: JDM ITR interior pieces? (penpen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by penpen &raquo;</TD></TR><TR><TD CLASS="quote">
another tip: calling him or anyone in here names after you come in here asking a question isn't going to make you any friends </TD></TR></TABLE>
just stating the facts, sorry, and there is a couple people on honda-tech i dont really want to be friends with, and its the ones that cant answer just answer a questions
Old Jan 31, 2005 | 01:16 AM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">Actually maybe i should put it this way. Everything will fit except the driver and passenger side faux cf vent and the shifter console with the carbon shifter plate. Everything else should fit.</TD></TR></TABLE>
actually, the driver and passenger side faux cf switch cover can be made to fit. The passenger side switch cover is "universal" so it WILL fit. I was able to get them on either side using both the actual jdm or usdm switch. The driver's side faux cf switch will require VERY MINOR yet unnoticeable modification to the door panel. But you WILL need the JDM RHD switch unit along with the faux cf switch cover simply because if you were to compare the JDM driver's side switch cover and the USDM driver's side switch cover, you will notice that the "screw holes" are angled in opposite directions. Meaning...the USDM driver's side window switch will not screw on ( and don't try modifying it so that it will fit....you're gonna ruin the faux cf piece). That's why I said earlier in this post to get the JDM Driver's side switch unit along with the faux cf power window switch cover ( which you can purchase from autosonic.com.....give them a call and talk to Ming if he still works there ) If you remove the door panels ( on any DC chassis integra ), you will notice that on the back side, there's these "ribs" so to speak. On the driver's side door, all you have to do is first "dry fit" the jdm itr faux cf switch cover WITH the JDM RHD driver's side switch unit attached/ screwed in to see how much of the "rib" you will have to remove. You won't have to remove much and since its on the inside of the door where no one can see, there will be no worries Afterwhich...just button everything up and here is the end result:
driver's side :
passenger side:
here's a link to some info I posted up on converting to an itr interior on a USDM teg
https://honda-tech.com/zero...age=2
hope it helps. I'll also try to get a pic of these "ribs" too whenever I replace the door lock handles That way....anyone reading this can see what needs to be done to "fit" the JDM faux cf switches on
Old Jan 31, 2005 | 09:06 AM
eg6hatch's Avatar
cool, thanks for all the info
Old Jan 31, 2005 | 08:10 PM
Default Re: (eg6hatch)
wasn't talking bout the switches. I know the switches fit. It's the vents that won't fit.
Old Jan 31, 2005 | 11:00 PM
Naruto's Avatar
Default Re: (jdmspoonitr)
ah.....oops. I need to get glasses heh.....my bad.
Old Feb 1, 2005 | 07:46 AM
jdmhawaii's Avatar
Default Re: (psychoticmindset)
The JDM CF plate that goes aroudn the shift boot, will not fit, ive tried, unless you wanna cut it
Old Feb 2, 2005 | 12:10 PM
Naruto's Avatar
Default Re: (jdmhawaii)
on a side note......I took my door panels off and replaced the nasty *** tan door lock handles ( that were painted black ) and replaced them with the actual OEM black ones. Wasn't hard. Literally took about 2-3 mins each side after the door panel was removed I also took the chance to take pics of the driver's side door panel to show how I fitted the RHD driver's side switch and faux cf switch cover onto the door. I'll post pics up tonight so as long as my internet stops acting gay.....
Old Feb 2, 2005 | 11:59 PM
justahobbie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychoticmindset &raquo;</TD></TR><TR><TD CLASS="quote">ah.....oops. I need to get glasses heh.....my bad. </TD></TR></TABLE>
No worries, been wondering about this for weeks. At lease I didn't have to make a post...!
Old Feb 8, 2005 | 06:17 PM
Naruto's Avatar
Default Re: (justahobbie)
just my luck that I took the pics to show you how to fit the RHD Driver's side switch unit along with the faux cf switch cover onto the US integra drivers side door panel.....and I accidentally deleted them before I uploaded them onto my online album If the weather is clear tomorrow...I'll retake the pics
EKk9
Feb 11, 2012 08:51 PM
99hondacura
Jul 21, 2009 03:18 PM
elwood
Feb 15, 2006 11:15 AM
is3oo
May 19, 2004 10:35 PM
type r 01-1063
Dec 12, 2003 10:18 AM
