FS: D16z6 Exospeed Head stage 2 cam / H&R Sports springs 89-00 Socal Pomona
Still have the exospeed head for sale asking $400. The head has been hot tanked, milled .020. The cam is stage 2 and come with Rev Valves and springs. Cam gear not included.
And H&R springs asking $100 + $10 shipped. Its for all 4 but only have pic of the fronts. Its a 1.9 front and 1.8 rear drop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itz Darave »</TD></TR><TR><TD CLASS="quote">so is the z6 head setup for allmotor or turbo?</TD></TR></TABLE>
Both depending on what kind of pistons you have high compression or low. It has aftermarket valves and springs that can handle both and a very aggressive cam that will run great with turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itz Darave »</TD></TR><TR><TD CLASS="quote">well my pistons would do 8.6:1 with a z6 head on a y8 block... </TD></TR></TABLE>
Are you planning on running turbo? Were are you getting your numbers looks kind of low. I am getting 9.2:1 from here http://www.knology.net/~jediklc/D.htm
i dont know if i want to buy a built head since... im only shooting for 300whp... and i got a d15b jdm sohc vtec head... and my set up should do 350whp easily... but with a built head i can get more probably...
Wow you want 300hp stock I think that is asking for to much. I would think with good engine management you can go over 200whp turbo stock. Not sure about 300whp. But I dont know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itz Darave »</TD></TR><TR><TD CLASS="quote">d15b sohc vtec head, y8 block with suzuki pistons and eagle rods... with a reall good turbo setup and a gt28rs as the turbo... </TD></TR></TABLE>
sounds good.
sounds good.
