Fully built ls/vtec swap forsale
Fully built LS/Vtec motor forsale.
99 b16a head
ITR Throttle body
Skunk2 manifold
RC 310 injectors
JUN 3 Cams
JUN valve springs
Skunk2 titanium retainers
SMSP 4-1 header
Aem fuel pressure regulator
vortech fuel rail
skunk2 cam gears
B18B block
81.25 MM Endyn Rollerwave 12.5:1 compression forged pistons
Eagle lightweight rods
new OEM Honda bearings with rebuild
ITR oil pump
B16 water pump
new timing belt
CTR crank pully
Hondata s2oo remapped for motor
B16 tranny, no grinds at any RPM
Exedy clutch
Full Swap (axles, motor, tranny,ecu, mounts, etc.): $5000 obo
Runs strong
zydeco_1@msn.com or IM me
99 b16a head
ITR Throttle body
Skunk2 manifold
RC 310 injectors
JUN 3 Cams
JUN valve springs
SMSP 4-1 header
vortech fuel rail
skunk2 cam gears
B18B block
ITR oil pump
B16 water pump
new timing belt
CTR crank pully
Exedy clutch
Runs strong
