stock color paint in spray can??
Old Jan 30, 2005 | 07:05 PM
komat's Avatar
Default stock color paint in spray can??
does anyone know if any company makes factory stock honda paint or anything close to stock color in a spray can.
i just did some body work on my fender and i want to paint it matching the rest of the body as close as possible
i think the color is call teal but not sure
heres the picture of the car
my car is the hatchback
Old Jan 30, 2005 | 07:12 PM
sockvtec's Avatar
Default Re: stock color paint in spray can?? (komat)
go to advance auto parts and llok for little cans on import auto spray and look under honda, and there should be some of the colors
Old Jan 30, 2005 | 07:26 PM
komat's Avatar
Default Re: stock color paint in spray can?? (zoomzoom92)
i will check that out tomrrow
Old Jan 30, 2005 | 07:30 PM
dxhatch93's Avatar
i used a few spray cans of matching paint and primer from the automotive store, and after a year and a half, this is what happens.
SD1222's Avatar
im pretty sure if u use spray paint to paint it u'll see streaks. Why not just take it to a paint shop? it's just the fenders that needs to be painted right? so im guessing it shouldnt cost much. But goodluck anyways. And post some after pics.
Old Jan 30, 2005 | 07:33 PM
freakin_eLRoD's Avatar
go to paintscratch.com. i and a few others on this board have bought some color matched rattle can paint from them with good results.
dxhatch93's Avatar
Default Re: stock color paint in spray can?? (jdm_spoonEG)
u wont see streaks if u do light even coats with wetsanding
Old Jan 30, 2005 | 07:35 PM
EK Josh's Avatar
Default Re: stock color paint in spray can?? (dxhatch93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxhatch93 &raquo;</TD></TR><TR><TD CLASS="quote">i used a few spray cans of matching paint and primer from the automotive store, and after a year and a half, this is what happens.
That **** sucks
Old Jan 30, 2005 | 07:42 PM
komat's Avatar
Aztec Green Pearl Clearcoat
is that my color?
Old Feb 1, 2005 | 01:38 PM
komat's Avatar
Default Re: stock color paint in spray can?? (powerBan.est1990)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerBan.est1990 &raquo;</TD></TR><TR><TD CLASS="quote">go to paintscratch.com. i and a few others on this board have bought some color matched rattle can paint from them with good results.</TD></TR></TABLE>
that place is overpriced $30 for a 12oz can...
i went to napa they do custom mix in spray cans only $17.99 for a 12oz can
Old Feb 1, 2005 | 01:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">
i went to napa they do custom mix in spray cans only $17.99 for a 12oz can </TD></TR></TABLE>
napa eh? hmm......well when you finish your little project post some pics...i would definetly like to see how the napa custom mix rattle can turns out.
Old Feb 1, 2005 | 01:54 PM
komat's Avatar
they basicly do the same thing as the online web site
they get your color code off your car
then they look it up on there computer for the paint that is needed
gather all the paint mix them into a can ,, shake it
then compress it into the spray can
Old Feb 1, 2005 | 01:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">they basicly do the same thing as the online web site
do they do this at all napa's? i'm definetly gonna have to look into that as I'd like to get some extra cans just incase i need to touch up anything.
Old Feb 1, 2005 | 02:00 PM
@ries's Avatar
Default Re: stock color paint in spray can?? (GGhatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GGhatchie &raquo;</TD></TR><TR><TD CLASS="quote">
That **** sucks </TD></TR></TABLE>
put some lotion on so it doesn't peel as bad.
Old Feb 1, 2005 | 02:10 PM
ukdm crx's Avatar
Well then you did something wrong cause I painted my spoiler with some duplicolor from Kragen and it's perfect up until about 2 weeks ago when someone decided to put glue on it and I had to scrape that **** off and scratch my spoiler.
Old Feb 1, 2005 | 02:18 PM
komat's Avatar
do they do this at all napa's? i'm definetly gonna have to look into that as I'd like to get some extra cans just incase i need to touch up anything.</TD></TR></TABLE>
beats me
the spray can had the napa logo on it
Old Feb 1, 2005 | 02:22 PM
beats me
thats cool...i'll have to check out my local napa to see if they do this. thanks for the info
Old Feb 1, 2005 | 02:43 PM
Destroyer24Seven's Avatar
Quote, originally posted by dxhatch93 »
The only thing you forgot to do is scuff the fender. With the e-coated fenders you have to scuff them with some 600-800 grit sandpaper so the paint has something to stick to. I would just scuff and clean the panel and shot some color again. It should stay for a long time if you do that.
Old Feb 1, 2005 | 03:47 PM
dxhatch93's Avatar
Default Re: stock color paint in spray can?? (Destroyer24Seven)
yea thats the one thing i didnt do. i just sprayed on the primer and the paint. can u explain more on scuffing the paint? i should just sand down the black finish, or should i sand it down to the metal?
Old Feb 1, 2005 | 04:18 PM
komat's Avatar
me too i want to know
also how should i spray the paint on if i want to spray a little area of the fender
Old Feb 1, 2005 | 04:19 PM
KrazyMC's Avatar
ill sand it down to the metal, cant go wrong there
Old Feb 1, 2005 | 04:49 PM
komat's Avatar
Default Re: stock color paint in spray can?? (KrazyMC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KrazyMC &raquo;</TD></TR><TR><TD CLASS="quote">ill sand it down to the metal, cant go wrong there </TD></TR></TABLE>
yep i 2nd that
Old Feb 2, 2005 | 03:17 PM
Yeah basically you have to scuff you surface underneath. In your case just sand the surface till it gets chalky. You do not want to sand down to metal. Then clean the whole area you sanded. Then go ahead and spray color. Use 600 or 800 grit sandpaper. You do not want to use anything coarser you will be able to see the scratches.
Old Feb 2, 2005 | 05:14 PM
justink4's Avatar
http://www.paintscratch.com
Old Feb 2, 2005 | 05:25 PM
numbnuts22715's Avatar
I know dupilcolor is pretty nice... my mom cheaped out on some other crappy brand from autozone, and it was very badly matched, and she had to end up repainting her whole stupid bumper, but I know for a fact duplicolor is matched pretty damn well.
