wrong ecu? help asap
Old Jan 30, 2005 | 04:10 PM
FG Two's Avatar
Default wrong ecu? help asap
i just finished an auto to manual swap on my 96 accord ex, i ordered the 96 ex ecu to do the swap, now when i rev up to 5k rpms my motor seems to bog down, it acts like its reached its rev limit at 5 then bogs down at 5.5k, did they send the lx ecu? or is it because i have a check engine light for my evap controll valve
please help asap
Old Jan 30, 2005 | 04:11 PM
Stoich EG2's Avatar
Default Re: wrong ecu? help asap (Phat4drVtec)
evap control valve....
Old Jan 30, 2005 | 05:05 PM
FG Two's Avatar
Default Re: wrong ecu? help asap (Advan06)
exhaust vapor .... something, its on the passenger side of the motor, above a large black cylinder, something for emissions
Old Jan 30, 2005 | 06:21 PM
raceACCORDingly's Avatar
whats the sticker code on the ecu?
Old Jan 30, 2005 | 06:52 PM
FG Two's Avatar
Default Re: (raceACCORDingly)
not sure, i will check tomorrow, i can use that sticker code to find out which ecu it is? i have never done anything with ecus before
Old Jan 31, 2005 | 12:01 AM
yep. just google the serial number and you should come up with something.
the serial number should go something like 37820-XXX-YYY
XXX tells you the year/make (i.e. POA = 94/95 VTEC; POB = 94/95 non-VTEC...)
YYY tells you if its for auto or manual (atleast thats how it is with OBDI)
im not very familiar with 96-97 obd II ECUs but I think POH is for VTEC and POJ is for non-VTEC (?).
Old Jan 31, 2005 | 08:06 PM
FG Two's Avatar
i looked on the ecu today, its different than my auto ecu, my original ecu was a poh, and the one they sent was poj, i should be able to get another one since they have a 90 day guarantee
Old Jan 31, 2005 | 08:57 PM
sounds good. i think since its the wrong ecu its in limp mode thats why it feels like its hitting the rev limit.
Old Feb 9, 2005 | 08:18 PM
FG Two's Avatar
i finally got the ecu in yesterday, its great, vtec screams and is much faster feeling than the auto, i still have a bad sensor (evap purge solenoid) or i didnt do a good job sealing the intake manifold after i took it apart, the ecu is searching for an idle, but it doesnt do it as much now, like its fixing itself
Pistolero281
May 26, 2017 12:44 PM
92yellowEG
Jul 26, 2007 09:19 PM
jdl3000
Jan 21, 2007 04:38 AM
Navid OG
Dec 18, 2003 01:18 PM
cbrman
Feb 11, 2002 08:51 PM
