Crx keeps dying ( please help)
Its a 91 stock crx si. I'll try to start my car and it will act like the battery is dead.
So I'll jump it. I starts warms up, runs fine. Well when I'm driving it will just die when I push in the clutch to stop at a light. When I take off from a light it boggs down real bad between 2000-3500 rpm. I also noticed when I have my turn signal
on it makes the seltbelt light flicker. Only thing I've done is have a headunit installed and changed my plug wires. Please need help badly.Thank you to all who reply
Could be number of things.
If you get the car running. Disconnect the battery and see if the car still runs. If it doesn't it's your altenator.
It would be your timing.
It could be a bad ignition switch (Where you put the key in)
Could be a bad floating ground somewhere.
HTH
HTH
moorevisual
10
Feb 6, 2014 05:38 AM
speedracer33
Jun 20, 2002 02:26 PM
