Hatch won't start up..
Old Jan 30, 2005 | 02:08 PM
SynTeg's Avatar
Default Hatch won't start up..
I just changed my headgasket on my 89 Civic Hatch DX w/ dohc zc, put everything back together and try to start her up but I get a Code 8(TDC). Would that cause the car to not even crank up at all? I know for sure its not the battery. Thanks
Old Jan 30, 2005 | 02:43 PM
Redline130's Avatar
Default Re: Hatch won't start up.. (SynTeg)
Did you plug all the wiring back in? Is your timing right? Check to see if your intake and exhaust cams are aligned.
Old Jan 30, 2005 | 09:41 PM
PrettyLude's Avatar
Default Re: Hatch won't start up.. (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Did you plug all the wiring back in? Is your timing right? Check to see if your intake and exhaust cams are aligned.</TD></TR></TABLE>
Old Feb 5, 2005 | 02:19 PM
SynTeg's Avatar
Yes I did
Old Feb 7, 2005 | 03:17 PM
Truman001's Avatar
Default Re: (SynTeg)
Chech to see if your starter is plugged in. Sounds stupid, but my buddies car through code 8 and that's what it was.
U N S E E N.
14
May 1, 2007 05:31 PM
Chef Andre
Apr 29, 2007 07:00 AM
philly-O
21
Dec 1, 2004 08:34 PM
speed.freak
Apr 7, 2004 12:25 PM
pg_thao
Jan 9, 2002 10:57 PM
