00' GSR brakes on 90 crx dx?... thanks!
Old Jan 30, 2005 | 02:01 PM
crxb20ed's Avatar
Default 00' GSR brakes on 90 crx dx?... thanks!
hey guys
just picked up a complete gsr brake setup front and back... I was wondering if I could use these whole knuckles? havent got to look at it much yet,, I htink I heard I have to get 90-93 ls knuckles to run my gsr calipers and rotors? also is the rear ebrake the same on these as the crx si? I believe its from a 00 gsr??? not to sure, and if the ebrake setup is the same should I just get the 90 si ebrake cables? thanks
Old Jan 30, 2005 | 03:41 PM
crxb20ed's Avatar
Default Re: 00' GSR brakes on 90 crx dx?... thanks! (crxb20ed)
buump
Old Jan 30, 2005 | 05:14 PM
crxb20ed's Avatar
Old Jan 30, 2005 | 08:04 PM
crxb20ed's Avatar
hey guys did some more research, sayd to use DA 90-93 Teg knuckles, I have a 90 dx, when I swapped my b20vtec, I got spindles from a SI I beleive cuase of the axle/spline hub size, I got some really nice 00 gsr front brakes,, I heard of using the 94' and up knuckles will give you crazy posistive camber, I have the car lowered and I have a camer kit, the arms already hitt he fenders.. and its still a little neg,., anyone know how much positive it makes the camber? aslo is the EX knuckles, will my b16 axles fit in the hubs? HELP! Want t use these brakes I got... thanks.. also! I got the complete rear brakes,I want to run a sway ba rin the rear but I heard not to use the TEGS LCA , so I would have to find crx si arms to use a sway bar? I know alot of "?";s help thanks!
Old Jan 31, 2005 | 04:14 PM
crxb20ed's Avatar
?? thanks
Old Jan 31, 2005 | 11:55 PM
crxb20ed's Avatar
ok guys any know? i heard I need 90-91 ex spindles anyone have these?? thanks, also i got the LCA from the 00' gsr, it has the sway bar mounts, I know in DEC. 04 of honda tuning of "wrenching "on my own 2" they put 00' TYPE -R LCA's on the ed/ed hatch, just wondering if I could use my gsr ones so I can put a say in the future on my DX, thanks!
Old Feb 2, 2005 | 02:44 AM
crxb20ed's Avatar
has any PERSONALLY tried putting 96 and up front integra/gsr knuckles? I hear all the horror stories about the alightment angles but I want to know, toe I can adjust, camber, car is lowered and I have a ingles camber kit, I was wondering if I turn the ecentric all the way in to correct that posistive camber??? its just they are 00's and are clean,, and my wheel bearigs are already sounding like **** , thanks
ridgeapd
May 27, 2010 04:07 PM
crxb20ed
11
Feb 12, 2005 09:16 PM
crxb20ed
Feb 6, 2005 03:26 PM
