difference in ecu's
Old Jan 30, 2005 | 12:04 PM
b16ahybrid's Avatar
Default difference in ecu's
The search is down right now, so I have a quick question,
Is there a difference between the 5th gen dx (p06) ecu and the 5th gen cx ecu?
I tried looking elsewhere but cant find any info on the cx ecu.
I'm putting a b7 head on a b8 block and need to know if the cx ecu will work. Thanks
Old Jan 30, 2005 | 12:10 PM
saywhat's Avatar
Default Re: difference in ecu's (b16ahybrid)
I wouldn't imagine there would be, is the cx still a p06. I think they are the same, both have only bare essentials, no vtec or anthing like that.
Old Jan 30, 2005 | 12:18 PM
dantastic's Avatar
the cx ecu is a P09. it has a lower rev limit than the p06 and is probably not optimized for the 16 valve head
Old Jan 30, 2005 | 12:51 PM
b16ahybrid's Avatar
Default Re: (dantastic)
So using the cx (p09) ecu with the dx will work fine?
I'm putting this set-up together for my brother. Right now he just needs the car to commute to and from work, eventually if he decides to increase performance he's most likely going to be swapping motors. I just don't want to spend more money then I need to. Thanks again.
mrprofits1
22
Jan 28, 2017 08:58 PM
noob1971
Dec 26, 2014 10:27 PM
LivinDreamsEK9
Mar 27, 2007 06:22 PM
CivilizedCiv
May 29, 2003 11:43 AM
Circuit8
Feb 27, 2003 12:25 PM
