my cluster
Old Jan 30, 2005 | 07:16 AM
Civic97s's Avatar
Default my cluster
i bought a cluster off of ebay and installed it
and its lights are very dim and in some places there is no light
i thought of just buying all new bulbs and i wanted to know what size or what to get
i also wanted to know if i can get some red lights for it
I have a 97 civic hatchback and the cluster is just stock but with an manual rpm gage
could you tell me where to find them?
i would appreciate eny help.
Old Jan 30, 2005 | 07:05 PM
Icyrain's Avatar
Default Re: my cluster (Civic97s)
Try the Honda dealer. I don't think you can buy the cluster bulbs just anywhere.
Modified by Icyrain at 12:18 PM 2/1/2005
Old Jan 30, 2005 | 07:41 PM
Icyrain's Avatar
Default Re: my cluster (Icyrain)
Please post a single thread not two of the same with different titles. Thank you.
https://honda-tech.com/zerothread?id=1131950
Old Jan 31, 2005 | 02:28 PM
Civic97s's Avatar
well thanks for your info
and sorry about the two posts
Old Jan 31, 2005 | 02:31 PM
Civic97s's Avatar
and how much do you think it would be for all balbs to be replaced
Old Jan 31, 2005 | 02:33 PM
Andres-eh2's Avatar
just put the bulbs from your old one. Sometimes its not even burnt bulbs its a bad contact. Slap on top of your dash and see if the light turn on
Old Jan 31, 2005 | 02:38 PM
Civic97s's Avatar
Default Re: (Andres-eh2)
ok ill try that
eny more sugestions will help ill try them all
Old Jan 31, 2005 | 02:42 PM
SOHC4life 96's Avatar
Default Re: (Civic97s)
The total for new bulbs from kragen will probably be about $5-$7. You need one really big bulb it could be #24 or 94 I forget which it is and 4 smaller bulbs, also could be 24 or 94.
Also check to see if the blue condoms are still on there. If they are pull them off and it will be much brighter.
Old Jan 31, 2005 | 02:48 PM
Civic97s's Avatar
Default Re: (SOHC4life 96)
the lights are out just in the 6-9 rpm and the hole fule light is out
if i pull out the blue condoms will it just be brighter or will it be alot whiter
Old Jan 31, 2005 | 02:53 PM
I just found the #'s for the bulbs. 1 #194 bulb and 5 #24 bulbs. If the bulb is blown, removing the condom won't do anything. Just go out and buy new bubls and do this.....
https://honda-tech.com/zerothread?id=1054824
It's the same concept for the 96-98 Civic. (same clusters) Only difference is the Climate control.
Old Jan 31, 2005 | 03:03 PM
Civic97s's Avatar
thank you so much that is really helpful
i really appreciate it
remove account
Mar 28, 2005 05:18 PM
Civic97s
Jan 30, 2005 07:38 PM
fwdftw
Mar 28, 2004 07:12 PM
itsJDMyo
14
Oct 19, 2003 05:22 PM
d15b7racer
Sep 5, 2003 08:37 AM
