hyrdrolock or water in engine?? How do you know!
What are the symptoms of sucking a little bit of water into the engine? I'm just curious because my car starting bogging a little again during the rain last night, however i still think its a dirty injector, but just want some info on this to be safer.
Unless your intake is very open to puddles or splash off the tires I would not think it's water. If it does studder in the rain I would check your plugs, wires, cap/rotor. Those item when worn act up when lots of moisture is in the air. If your filter is open though, check and see if it has water in it first.
dude_uuk
16
Jul 28, 2008 09:30 PM
