Toda Products?
It all depends on how your motor is setup whether or not these cams will make power or not. If you have more compression, and a lot of bolt ons, then the C's would be a wiser idea, whereas a highly tuned bolt on only street motor can use the B's...albeit at a slight sacrifice in the bottom end...unless your running b20vtec, then things won't be as bad...just my .2 cents
