Stock rear sway with Ominpower Coils?? installing as i write.
Old Jan 29, 2005 | 07:56 PM
spyz34's Avatar
Default Stock rear sway with Ominpower Coils?? installing as i write.
I just bought the Omni setup with jdm itr lca's. What i need to know is if my old stock sway will fit on the new lca's. If not then when I order a sway bar should it be for my car or for itr. Thanks soo much.
Old Jan 29, 2005 | 08:26 PM
onePOINTsix's Avatar
Default Re: Stock rear sway with Ominpower Coils?? installing as i write. (spyz34)
if you cant figure out how to use the stock one (i have no clue sorry) order up a Suspention Techneques rear sway with the 88 adapter (ITR style LCA year). Then it'll bolt right up
Old Jan 29, 2005 | 10:37 PM
spyz34's Avatar
Default Re: Stock rear sway with Ominpower Coils?? installing as i write. (onePOINTsix)
Thanks, I used a diffenrent bolt and nut and the old one bolted right up. Now if I could only figure how to adjust height.
snowboardgeek1
Aug 15, 2014 06:46 PM
B20EF
Jul 9, 2008 04:44 AM
snowboardgeek1
Suspension & Brakes
Oct 14, 2006 10:27 PM
roninb18
Feb 15, 2003 01:46 AM
