Compression Test...how to?
Old Jan 29, 2005 | 07:11 PM
94DOHCDELSOL's Avatar
Default Compression Test...how to?
Ok, I know this is a simple question, but how do you do a compression test, where should the numbers be, and what exactly do they mean?
Old Jan 29, 2005 | 07:21 PM
toEknEEg's Avatar
Default Re: Compression Test...how to? (94DOHCDELSOL)
check out cspeed 's how to site. they have that and alot of other helpful how to's
it matters on your motor... but numbers should be around 180psi to around 240psi
the thing that really matter is that all the numbers are constistent throughout all four cylinders...
search dude.. there is alot about this... all you had to do was type in compression..
05 members
numbnuts22715's Avatar
http://www.c-speedracing.com/h...c.php
http://www.c-speedracing.com/h...t.php
these two links should help you out.
people cant tell you where numbers should be without knowing what engine you have...
Old Jan 29, 2005 | 07:34 PM
Default Re: Compression Test...how to? (numbnuts22715)
I should've used the search function, sorry about that...it's a b16A3 engine
Old Jan 29, 2005 | 07:45 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
remove all spark plugs, disable ignition, stick the compression gauge to each spark plug hole, check the psi, make sure the readings arent 20 psi of each other, if it is proceed with a leak down test
CTR_B
Apr 22, 2008 04:27 PM
jorge59la
Mar 16, 2007 10:34 PM
Nisif
Apr 12, 2005 09:13 AM
builtprelude
Jan 22, 2004 10:49 PM
98cwtypeR
Jun 4, 2003 10:29 PM
