How do i get this shock off ????
Old Jan 29, 2005 | 06:43 PM
0ptimus prime's Avatar
Default How do i get this shock off ????
For the life of me, i cannot get this shock of my g/f's car. This is the rear, passenger side btw. I know i'm supposed to push down on the LCA so that the shock will free up, but there's too much damn tension. There wasn't this much tension on my civic, is there another way i'm supposed to do this? Should i disconnect the upper A arm? Car is a 93 prelude. Thanx
Old Jan 29, 2005 | 06:46 PM
BauleyCivic's Avatar
Risky Business
Default Re: How do i get this shock off ???? (0ptimus Prime)
Try disconnecting the upper a arm, and unbolt the LCA/shock assembly from the chassis so you can pound the LCA out with a hammer.
Old Jan 29, 2005 | 11:48 PM
kaiba's Avatar
Default Re: How do i get this shock off ???? (BauleyCivic)
Not trying to be an ***, but shouldn't this be post in the prelude forum.
Old Jan 30, 2005 | 12:14 AM
VinhTEC's Avatar
wow that looks weird but i worked on a fith gen prelude or whatever gen the last one was anyway i just steped on the lugnuts and push down while some one pulled the shock out anyway u should just take the uper control arm off it is wayyyyyyyyyyyyyyyyy easyer for any one wit hondas anyway just smak the top of the knuckle where the upper control arm meets and if that dont work go get a 2 jaw ball joint seperater : ) and put that sob out if is stubborn!!!!!!!!
Old Jan 30, 2005 | 07:57 AM
ironlung78's Avatar
Default Re: How do i get this shock off ???? (VinhTEC)
or you could borrow one of those cheap spring compressors from autozone and compress the spring and inc or so and it should come right out
scia220
May 11, 2012 01:20 PM
wolf95
Jun 7, 2011 07:33 PM
E-Money
Dec 16, 2009 09:37 AM
mt23vtecbb2
May 23, 2005 04:15 PM
0ptimus prime
Feb 1, 2005 10:01 AM
