Extended wheels studs needed w/ 5mm spacer???
Old Jan 29, 2005 | 04:11 PM
Chris93Si's Avatar
Default Extended wheels studs needed w/ 5mm spacer???
Couldn't find anything though search other than you need about 6 full turns of the lug to secure the wheel.
Wondering if anyone knows for sure if w/ a 15x7 +44mm offset wheel and 5mm spacer will I need to run extended studs? Thanks in advance for any help.
Also any recommended brands of spacers and studs? From searching H&R spacers and ARP studs seem to come up a lot.
Edit: Also wondering if w/ the wheels listed above and the 5mm spacers w/ 205/50 Azenis will rub. Any idea? TIA guys.
Modified by Chris93Si at 5:42 AM 2/5/2005
Old Jan 29, 2005 | 04:35 PM
.RJ's Avatar
.RJ
Default Re: Extended wheels studs needed w/ 5mm spacer??? (Chris93Si)
No spacer needed
You can get 1/4" spacers from pepboys
Old Jan 29, 2005 | 04:42 PM
Chris93Si's Avatar
Default Re: Extended wheels studs needed w/ 5mm spacer??? (.RJ)
Jep I know the wheel fits, they're on the car now but I'm thinking soon I may need a spacer to make it fit
Just wondering if w/ that spacer I'll need the extended studs.
Thanks for the help though homay
Old Jan 29, 2005 | 05:17 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">No extended wheel studs needed with a 5mm spacer
if you do end up getting them, Acura TL wheelstuds work good too
Old Jan 29, 2005 | 06:03 PM
DontBlink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">
Also any recommended brands of spacers and studs? From searching H&R spacers and ARP studs seem to come up a lot.</TD></TR></TABLE>
i had the H&R spacer, actually i have the 5mm somewhere in a box,but i had my buddy make me some 7mm instead. as far as studs we broke a few skunk2 studs torqueing them to factory honda specs, id look into getting the ARP studs if you get them.
Old Jan 29, 2005 | 07:04 PM
db8sirg's Avatar
arp comes in standard length also (had them on my last car). just in case you just want stronger studs.
spacers wise i recommend ss works.
i like my set a lot.
comes in 3/5/7mm. and they also have 15mm.
Modified by db8sirg at 12:40 AM 1/30/2005
Old Jan 29, 2005 | 07:36 PM
db8sirg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Jep I know the wheel fits, they're on the car now but I'm thinking soon I may need a spacer to make it fit
Thanks for the help though homay </TD></TR></TABLE>
getting some spoon calipers?
ss works spacers btw
Old Jan 29, 2005 | 08:21 PM
Chris93Si's Avatar
Default Re: Extended wheels studs needed w/ 5mm spacer??? (db8sirg)
Thanks for the help guys, so no extnded studs needed, that's good to hear
Old Jan 29, 2005 | 08:55 PM
B2FiNiTY's Avatar
Where can you get SS works spacers?
Old Jan 29, 2005 | 09:14 PM
uNF$@#!'s Avatar
Default Re: Extended wheels studs needed w/ 5mm spacer??? (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
if you do end up getting them, Acura TL wheelstuds work good too </TD></TR></TABLE>
i smell groupbuy on TL studs
more seriously, how much longer is a TL stud?
Old Jan 29, 2005 | 09:17 PM
BlueR's Avatar
Default Re: Extended wheels studs needed w/ 5mm spacer??? (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">
more seriously, how much longer is a TL stud?</TD></TR></TABLE>
shorter than ARP extended but longer than OEM Integra
Old Jan 29, 2005 | 09:21 PM
uNF$@#!'s Avatar
i would like a pictogram please
Old Jan 29, 2005 | 09:26 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">i would like a pictogram please </TD></TR></TABLE>
good luck with that
Old Jan 29, 2005 | 09:35 PM
db8sirg's Avatar
Default Re: Extended wheels studs needed w/ 5mm spacer??? (B2FiNiTY)
Special ordered from taka kaira
integra type r ss works Wheel spacer set (7/5/3 mm) 5x114.3
(http://www.on.rim.or.jp/~ssworks/list_intext.html)
¥8000 (price for pair)
Old Jan 29, 2005 | 09:36 PM
BlueR's Avatar
thats not a bad price at all
Old Jan 29, 2005 | 09:52 PM
eg_type_r93's Avatar
ss works - aj racing
Old Feb 5, 2005 | 01:43 AM
Chris93Si's Avatar
I edited my original post to include another question, any help is greatly appreciated
Old Feb 5, 2005 | 09:30 AM
Chris93Si's Avatar
Anyone?
Old Feb 5, 2005 | 10:03 AM
.RJ's Avatar
.RJ
Chris - I used 15x7 +45 offset wheels all year and never had an issue with rubbing at all - I dont think the spacers are neccessary at all... if you did use them, you *may* need to roll the rear fenders.
Old Feb 5, 2005 | 10:09 AM
donz's Avatar
Are the TL stud long enough after the spacer? what's the price difference between the TL studs and the ARP studs?
ok I did a search and it looks like the ARP studs are a lot longer than stock. the "new" versions have a threadless part for the ease of putting lugs back on, so it looks like open ended lugs are a must.
The TL lugs are shorter than ARP, I can't really get specs from the pics, but the look to be about 6-7 turns longer, and the ARP ones are like 2x as long as the stock ones.
Anyways, anyone up for 96-98 TL rear stud GB?
Modified by donz at 11:48 AM 2/5/2005
Old Feb 5, 2005 | 10:55 AM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Chris - I used 15x7 +45 offset wheels all year and never had an issue with rubbing at all - I dont think the spacers are neccessary at all... if you did use them, you *may* need to roll the rear fenders.</TD></TR></TABLE>
I believe he was asking about the spacers cause his w0rk wheels will need some spacing if he decides to do a caliper upgrade. He was hinting that he may need more clearance in the future.
Old Feb 5, 2005 | 01:53 PM
Kengs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8sirg &raquo;</TD></TR><TR><TD CLASS="quote">
yummy!
Old Feb 5, 2005 | 04:01 PM
Mario's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Couldn't find anything though search other than you need about 6 full turns of the lug to secure the wheel.
Hey friend.
I know Giff had 15x7 +38offset Kosei K1 rims w/ 205/50/15 Azenis on his Integra without any rubbing issues. I also had the same setup on the EK for a while, no problem either.
your 44mm offset plus the 5mm spacer would effectively make it a +39mm offset combo, so you're golden.
Getting Spoon 4pots are we?
Old Feb 5, 2005 | 05:32 PM
Chris93Si's Avatar
Default Re: Extended wheels studs needed w/ 5mm spacer??? (Mario)
Good to hear, thanks for the info Wario
Old Feb 5, 2005 | 05:33 PM
.RJ's Avatar
.RJ
George had some problems w/ rubbing on track (+38 offset spinnerz), but for street i guess it would be ok.
