What is the part number for this NGK plug?
Old Jan 14, 2002 | 11:26 AM
blazin's Avatar
Default What is the part number for this NGK plug?
I need to know the right part number for the correct V-Power NGK plug to run in a B18C5 with 12.1:1 comp. This is N/A settup and I'm not sure what heat range I need.
Old Jan 14, 2002 | 11:41 AM
sgT's Avatar
sgT
Default Re: What is the part number for this NGK plug? (blazin)
I recommend Platinum PFR6G-11 or PFR7G-11
even the BKR7EVX-11 isnt bad either
Old Jan 14, 2002 | 12:32 PM
Mike K's Avatar
Default Re: What is the part number for this NGK plug? (sgT)
BKR7E-N11 is available at Honda/Acura dealer under the part # 98079-5714J
PFR6G-11 is 98079-5614H. Both are good for high compression.
ITR platinums are available in one step colder as well.
NGK# PFR7G-11
Honda# 98079-5714H
Old Jan 14, 2002 | 12:55 PM
naturalvx's Avatar
Default Re: What is the part number for this NGK plug? (Mike K)
I loved the BKR's, I change my plugs like I change my oil so the price was right.
Old Jan 14, 2002 | 09:02 PM
seek167's Avatar
Default Re: What is the part number for this NGK plug? (naturalvx)
check out http://www.clubplug.net they should have it cheap
Old Jan 15, 2002 | 06:29 AM
TodaCivic's Avatar
Default Re: What is the part number for this NGK plug? (seek167)
Why not go to Advance Auto parts? you can get any V-Powers for 1.50$ a piece.
They have to order them but one day wont hurt anything, plus auto zone and all have them too.
I have been running the BKR7E-N11 and am pleased with them.
LATA
Old Jan 16, 2002 | 07:07 AM
Bbasso's Avatar
What about "DENSO 1K20" gap at 1.1mm ???
Old Jan 16, 2002 | 07:13 AM
HX_Guy's Avatar
Default Re: What is the part number for this NGK plug? (Bbasso)
Does anyone use the Bosch ones? Or only NGK?
Old Jan 16, 2002 | 08:05 AM
sgT's Avatar
sgT
Default Re: What is the part number for this NGK plug? (HX_Guy)
personally I think bosch plugs suck as I havehad bad experiences with them.
Old Jan 16, 2002 | 08:07 AM
coquinn's Avatar
What are you guys gapping your plugs at for 12:1 compression? TIA.
sgT's Avatar
sgT
Default Re: What is the part number for this NGK plug? (coquinn)
1.1mm
Old Jan 18, 2002 | 07:50 AM
HX_Guy's Avatar
Good lord! The PFR6G-11 is $12.00 each!
I think Ill go for the BKR7E-N11 for $1.75 each
Mike K recommends them...and he knows his shiet
[Modified by HX_Guy, 8:50 AM 1/18/2002]
Old Jan 18, 2002 | 07:52 AM
junglistgsr's Avatar
i run the BKR6E-N11's and they are great...nice and cheap too, all of the local auto parts stores around here stock them so they are easy for me to find too
Old Jan 18, 2002 | 07:53 AM
HX_Guy's Avatar
Default Re: What is the part number for this NGK plug? (junglistgsr)
Yep, I just called B.A.P. and they have 21 of them in stock
sgT's Avatar
sgT
They are stock plugs for ITR.
what can i say, you have to pay for performance.
Old Jan 18, 2002 | 07:54 AM
HX_Guy's Avatar
I
Would they actually make a noticable differance over say the BKR7E-N11s?
Old Jan 18, 2002 | 07:59 AM
I
they are only expensive because they are platinum......copper is actually a better conductor than platinum and will perform better....just wont last as long
edit: fixed my engrish
[Modified by junglistgsr, 8:59 AM 1/18/2002]
Old Jan 18, 2002 | 08:00 AM
HX_Guy's Avatar
What effect does the length of the electrode (is that what is called?) have on the performance of the plug?
See how in the bottom picture the white parts is longer?
sgT's Avatar
sgT
I see a noticable difference over copper.
I believe a lot of it has to do with the electrode design.
the bkr7evx11 are only 5-6 each.
You cant compare pictures like that.
The projection varies which is why they are labeled.
Old Jan 18, 2002 | 08:03 AM
really? you think the PFR performs better because of its electrode design? because copper is known to be a better conductive element than platinum.
HX_Guy's Avatar
What do you mean? The picture shows exactly what Im referring to..I have seen both plugs in person.
Old Jan 18, 2002 | 08:04 AM
HX_Guy's Avatar
Here is the BKR7E by the way...
Old Jan 18, 2002 | 08:07 AM
HX_Guy's Avatar
EDIT: Nevermind
[Modified by HX_Guy, 9:08 AM 1/18/2002]
Old Jan 18, 2002 | 08:19 AM
sgT's Avatar
sgT
thats what they all say, but my car performs so much better with the fine
tip electrode.
Old Jan 18, 2002 | 08:26 AM
tip electrode.
interesting, does NGK have any fine tip plugs in copper rather than platinum? that fit the b18c?
