sitting uneven
Old Jan 29, 2005 | 12:21 PM
dso's Avatar
dso
Default sitting unevenly
why would my hatch be uneven (the left is lower than the right)? Do any of y'all have experience with this issue, suggestions and help would be much appreciated.
Modified by EG6_tuner at 10:06 PM 1/29/2005
Old Jan 29, 2005 | 12:24 PM
Andres-eh2's Avatar
If its just the front then it may be that your the tranny isnt as heavy as the block maybe? Therefore causing a gangster lean...
Old Jan 29, 2005 | 12:27 PM
hatchling37's Avatar
Default Re: sitting unevenly (EG6_tuner)
Are you really fat? j/k This may sound like a stupid question, but do you have coilovers on it? If so, it merely needs adjusting (assuming your car isn't corner-weighted or anything). The heaviness of the motor doesn't sound far fetched. That could be it.
Old Jan 29, 2005 | 12:57 PM
MikeD718's Avatar
Default Re: sitting unevenly (hatchling37)
My 98 coupe and a few others ive seen lean to the driverside a little too.
Old Jan 29, 2005 | 01:09 PM
dso's Avatar
dso
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">If its just the front then it may be that your the tranny isnt as heavy as the block maybe? Therefore causing a gangster lean...</TD></TR></TABLE>
nah it did the same thing even before my swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">This may sound like a stupid question, but do you have coilovers on it? If so, it merely needs adjusting (assuming your car isn't corner-weighted or anything).</TD></TR></TABLE>
nah i don't have em
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeD718 &raquo;</TD></TR><TR><TD CLASS="quote">My 98 coupe and a few others ive seen lean to the driverside a little too. </TD></TR></TABLE>
what did you do to correct it?
Old Jan 29, 2005 | 01:12 PM
Frozen E's Avatar
H-T White Ops
my 98 hatch did that on stock suspension. I took it to the dealership and they checked it. I think if the left and right side are within 23mm of each other they consider it to be "within specs" even though it looks fucked up. I guess that it's a normal thing they expect to happen.
Chalk it up to your driver's side always having a "load" on it when it's driven so it settles more than your passeneger side does. Unless you have a twin that drives with you everywhere you go you'll get this I guess. Another thing you could do is to pull the suspension out and swap the left and right assemblies. No need to get a spring compressor or anything. Just swap the whole thing. Shock and springs still assembled.
Old Jan 29, 2005 | 01:17 PM
dso's Avatar
dso
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">Another thing you could do is to pull the suspension out and swap the left and right assemblies. No need to get a spring compressor or anything. Just swap the whole thing. Shock and springs still assembled.</TD></TR></TABLE>
well if it's 23mm then all of the 23 is used makin my passenger side look whack. Oh so you think that swappin the suspension would really work?&lt; Is that what you did?
Old Jan 29, 2005 | 01:20 PM
civictildeath's Avatar
Default Re: (EG6_tuner)
ya getting new springs would help correct this cause they do get worn and lose their spring ability
Old Jan 29, 2005 | 01:57 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_tuner &raquo;</TD></TR><TR><TD CLASS="quote">well if it's 23mm then all of the 23 is used makin my passenger side look whack. Oh so you think that swappin the suspension would really work?&lt; Is that what you did?</TD></TR></TABLE>
I just went and got myself some skunkworks (yep, before they switched their name to Skunk2) coilovers and adjusted 'em that way. But swapping your suspension from left to right should do the trick. It might make your driver's side sit high for a month or so ntil you can squish those down to where the passenger side now sits but it should work out in the end.
totsie7944
Feb 4, 2008 08:34 AM
LoW ToNE
12
Jan 17, 2008 07:47 AM
tdo
Feb 2, 2007 03:33 PM
efHondefender
Welding / Fabrication
Jul 11, 2006 04:54 PM
jisu009
May 22, 2003 06:48 AM
