temp gauge on cluster does not go up
Old Jan 29, 2005 | 07:55 AM
tuphatt's Avatar
Default temp gauge on cluster does not go up
My temp gauge in my cluster is not moving to HOT even when the car is warmed up. It just stays on the bottom at cold.
It was working a couple of weeks before my o2 sensors went bad. I already replaced those and have no CEL light. But I don't think that was the problem.
I don't have Indiglo gauge covers so I don't think it is stuck.
My gut tells me it is thethermostat. Or it could be the temp control switch. I would lrather choose the right one and save money. Instead of replacing every damn thing on my car.
What do you guys think? Thanks!
Old Jan 29, 2005 | 08:03 AM
hypoxvi's Avatar
Default Re: temp gauge on cluster does not go up (tuphatt)
change the thermostat. even if it's not the problem it's only a 2 dollar part so replacing it would tell you what the problem is, and if it's not the thermostat then replace the switch. but it's most likely the thermostat anyway so do that.
Old Jan 29, 2005 | 08:06 AM
Jonzo's Avatar
From: Toronto, Ontario, Canada, North America,, Earth
Default Re: temp gauge on cluster does not go up (hypoxvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypoxvi &raquo;</TD></TR><TR><TD CLASS="quote">change the thermostat.</TD></TR></TABLE>
klinster
Sep 23, 2009 04:19 PM
klinster
Jan 17, 2009 01:08 PM
rollinonblades
Oct 14, 2008 02:49 AM
integraslut78
Aug 13, 2008 10:35 AM
ilovemydc2
Nov 18, 2004 10:04 AM
