Looking to turbocharge D15B2
Old Jan 29, 2005 | 12:46 AM
travisscivic's Avatar
Default Looking to turbocharge D15B2
I am looking to turbocharge my 1990 Honda Civic with the 1.5L D15B2. So far I know that I will need to replace the gaskets, upgrade the fuel system, lower the compression, and put in stronger connecting rods. How much can the stock drive train handle? Does anybody have any good sources for aftermarket connecting rods, or any other reccomendations?
Old Jan 29, 2005 | 12:50 AM
Redline130's Avatar
Default Re: Looking to turbocharge D15B2 (travisscivic)
I hope you plan on converting it to MPFI first.
Old Jan 29, 2005 | 04:55 AM
Pantysniffer's Avatar
Default Re: Looking to turbocharge D15B2 (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">I hope you plan on converting it to MPFI first.</TD></TR></TABLE>
no point in turbo'ing if you dont plan on doing the MPFI conversion first as stated.
but you can also use p29 or pg6b(86-89 integra) pistons on the b2 as well, but that will bump up the compression though. look into a p&p and a 3/5 angle valve job as well to make more power.
this site is geared more towards b/h/k-series performance, so i'd advise you to check out http://www.sohchonda.com and http://www.d-series.org and http://www.homemadeturbo.com
Old Jan 29, 2005 | 05:10 AM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travisscivic &raquo;</TD></TR><TR><TD CLASS="quote">I am looking to turbocharge my 1990 Honda Civic with the 1.5L D15B2. So far I know that I will need to replace the gaskets, upgrade the fuel system, lower the compression, and put in stronger connecting rods. How much can the stock drive train handle? Does anybody have any good sources for aftermarket connecting rods, or any other reccomendations?</TD></TR></TABLE>
After you convert to mpfi I would say the stock motor is good for about 180whp reliabley with a good tune..
Get some eagle rods,JE pistons with around 9:?:?..and get some fuel management and get a nice exospeed cam or si cam and you could start makin some power a proper sized turbo..
simonEp3
Aug 21, 2007 05:05 AM
KooK
Feb 14, 2006 12:13 PM
unknown0001
29
Oct 20, 2005 04:12 PM
travisscivic
Jan 29, 2005 01:18 AM
gregsr
Jul 20, 2003 04:39 PM
