hasport hydro conversion need help
which L bracket do I use for this conversion? I previously had a cable tranny, so i am using the cable b16 bracket. I know for a fact that the hydro tranny uses a 19mm bolt, but the b16 cable bracket holes aren't large enough for the 19mm bolts... for those that have done this conversion before please help. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock-n-drop »</TD></TR><TR><TD CLASS="quote">Drill the two holes on the rear L bracket with a 9/16ths drill bit, then it should accept the bigger hardware...</TD></TR></TABLE>
You can do this, but if you do not have the hardware to, you can order the bracket pre-drilled from Hasport.
revikan
Sep 2, 2010 04:27 PM
JCracer723
Aug 14, 2007 10:08 AM
