1988 CRX SI heater control system needs something that works
Old Jan 28, 2005 | 08:17 PM
BOSS-REX's Avatar
Default 1988 CRX SI heater control system needs something that works
I have a 88 CRX SI and the heater control switches don't work and can't be fixed, a knew one is too much money, any nice alternative's, or has anybody put the standard civic of the same generation in a CRX SI. the standard is cable activated in stead of electrical.
Old Jan 28, 2005 | 08:24 PM
Speed PHreak's Avatar
Default Re: 1988 CRX SI heater control system needs something that works (BOSS-REX)
You can swap the Civic cable driven controls into a CRX. You just have to rape the HVAC peice from a civic, as well as the drive cables. You also have to remove the first actuator arms bolted onto the air box(behind glove box) and vent box(at drivers floar board, above/to the right of the gas pedal). I've done the *reverse* of this in my 91 Civic, by installing the CRX HVAC controls, wiring, and stepper motors. I noticed that the CRX and Civic's share a common casting for the air and vent boxes. It'll take a little work to remove and install the cables, but it will be functional when you're done...
Though I'd suggest going junk yard hoppinf for a CRX to ****** the HVAC controls out of. You'll hate the Civic's ghey levers, versus the CRX push button stuff.
payneth
Dec 26, 2003 07:14 PM
thecorey
Aug 10, 2003 07:01 PM
PhatHardy
Jan 29, 2003 11:45 PM
tysf
11
Aug 3, 2002 04:17 PM
