Safe to run ITR cams with stock valve springs ?
Old Jan 14, 2002 | 09:20 AM
nwarp's Avatar
Default Safe to run ITR cams with stock valve springs ?
Just wondering if its possible to run ITR cams with stock valve springs, and not having to worrie about "valve float".
Old Jan 14, 2002 | 09:37 AM
6SPD_EK's Avatar
Default Re: Safe to run ITR cams with stock valve springs ? (SPOON SPEC DC2)
you should be ok - as long as you keep the stock redline - I myself would spend the $$$ and get new OEM ITR intake valvesprings (inner and outer) and switch your current GSR intakes to the exhaust side (because GSR intakes are the same as ITR exhaust springs) - BTW mike at IPS was selling new ITR intake springs for around 85.00 - that was a special tho - good luck
Old Jan 14, 2002 | 09:43 AM
speedymon's Avatar
Default Re: Safe to run ITR cams with stock valve springs ? (2000-4DRGSR)
Yeah i just got all that stuff (springs, retainers, and valves). Mad cheap and an extra piece of mind.
Old Jan 14, 2002 | 09:45 AM
nwarp's Avatar
thanks guys
Old Jan 15, 2002 | 07:31 PM
joemama's Avatar
New User
how much more installation time is it to replace valve springs while replacing cams?
Old Jan 15, 2002 | 08:13 PM
StinkyTofu's Avatar
Default Re: Safe to run ITR cams with stock valve springs ? (joemama)
200+ dollars cause you have to pull off the head while camshafts only require you to pull off the valve cover
Old Jan 15, 2002 | 10:51 PM
ingrate's Avatar
25 Year Member
Default Re: Safe to run ITR cams with stock valve springs ? (B-18C1)
you can use compressed air in the cylinders to keep the valves from falling in
JDAMC
Jul 27, 2006 04:31 AM
SofaKing
Jan 18, 2005 09:01 PM
sjteg
Jan 5, 2004 05:32 PM
mattL
Apr 30, 2002 11:34 AM
GSR -97
Nov 26, 2001 09:25 AM
