FS: 2cc 84mm COATED WISECO PISTONS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!
These are brand new in the box.
Comes with rings, wrist pins, and paperwork.
moley coated
<FONT COLOR="BLUE"><FONT SIZE="10">SOLD!!!!!</FONT></FONT>
application will vary compression.
[IMG][http://www.skafia.com/myPix/Turbo%20...66849.jpg/IMG]
Modified by Turbo R at 10:34 PM 3/10/2005
Modified by Turbo R at 1:33 AM 3/16/2005
moley coated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">What is the compression ratio for those pistons?</TD></TR></TABLE>
Depends on what Motor you have and what stroke, also what head you are running. What is your set up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">
Depends on what Motor you have and what stroke, also what head you are running. What is your set up?</TD></TR></TABLE>I have a full B18B setup (stock 89mm stroke with RS Machine iron-sleeved block). The sleeves are currently 81mm bore size...boostin w/ Precision SC61 ...Cometics headgasket...HONDATA tuned. The LS head is basically stock besides the mild port-matched intake/exhaust ports. OH yeah..by the way, I would like to have 9:1cr pistons.
10.6:1 CR with stock thickness headgasket or 10.2:1 with a Cometic .043" gasket.
This is a GREAT piston for a B16A turbo though also.
compression varies which each persons setup so dont ask me what compression they are!!!
THEY HAVE A 2cc dome.
you can calculate your compression on http://www.c-speedraing.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo R »</TD></TR><TR><TD CLASS="quote">!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! </TD></TR></TABLE>
