obd0-obd1?
Old Jan 28, 2005 | 04:43 PM
90acintegra's Avatar
Default obd0-obd1?
i currently have a b18a in my 90 integra but soon i am gettin a newer b18b1 and i read alot thet there is a obd0 to obd1 conversion involved but when i went to ask my auto teacher he said there is no obd0 there is just obd1 and obd 2 and that my car is odb1 so is there a conversion i will need to do?
also does anyone know where i can get some replacement door panels,i have power windows and my door panels are messed up pretty bad.
Old Jan 28, 2005 | 04:45 PM
90crxsib16's Avatar
Default Re: obd0-obd1? (90acintegra)
obd0(non-obd) to obd1 you need:
obd1 ECU
4 wire o2 sensor
obd1 dizzy
Have fun
Old Jan 28, 2005 | 04:48 PM
hondaguyef's Avatar
Tell your shop teacher he is wrong. Your car is OBD0/Pre obd. Why are you switching your head? The only difference in the b18a'(90-91) and 92+(b18a/b's) is the cams(very minimal at that). Unless you plan to run Uberdata or crome there is no reason to make the obd0-obd1 switch.
Phil
Old Jan 28, 2005 | 04:49 PM
Blown90hatcH's Avatar
Your teacher is confused. You need the following to convert to OBD1:
My OBD0-1 conversion harness
OBD1 distributor
OBD1 ecu
4 Wire O2 sensor
Let me know if you have any more questions or need any more help.
Jason
http://www.JKobdconversionharness.com
Old Jan 28, 2005 | 05:00 PM
4drEF's Avatar
Keyboard Humorist
I posted about this before.
Everyone on Honda-tech that says OBD-0 is wrong.
Your teacher was right as far as that goes... there is/was never an OBD-0.
The very first version of OBD was version 1 - OBD-1.
Everything before that (PGMFI... FI... whatever) was before the OBD so it's pre-OBD.
OBD-0 is just what we call it in short, but it's really not.
Nobody invented a version 0 of OBD.
BUT, like Blown90hatcH wrote, your teacher is dead wrong about the OBD version of your car. Your 90 teg is pre-OBD and not OBD-1.
Old Jan 28, 2005 | 05:27 PM
Targa250R's Avatar
be professional
Default Re: obd0-obd1? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">I posted about this before.
I've posted about it before also, because it irks the hell out of me when people call it "OBD-0" instead of "pre-OBD" or "non-OBD" or whatever.
Its just like everyone using the wrong f'ing chassis codes. Everyone insists on being lazy and/or ignorant, using the wrong terminology in either some sort of childish defiance or just pure stupidity. Confusion like this is what results.
&lt;/rant mode&gt;
Old Jan 28, 2005 | 05:44 PM
slate13530's Avatar
Default Re: obd0-obd1? (Targa250R)
Okay well since we're on the topic of pre-OBD and OBD-1. I have a question for all you guru Honda ppl out there.
I swapped the engine in my 89Si Hatch with a ZC SOHC V-tec. Kept it pre-OBD, but is it mad hard to just make OBD-1. I still have the OBD-1 manifold, but aside from the dizzy should I just get an entire engine harness from a 92-95 Civic w/V-Tec and adapt it or what can I buy. I'm sorry there is just too much info out there and it gets confusing. I know I can just make a rig up a connection for the V-tec and make it activate, but rahter do it properly or know if it's even worth going to OBD-1.
BTW don't want to jack the thread either.
Old Jan 28, 2005 | 06:00 PM
4drEF's Avatar
Keyboard Humorist
Default Re: obd0-obd1? (slate13530)
OBD-1 swap is stupid simple.
Take a look at the reply made by 'Blown90hatcH'.
You get a conversion harness, OBD1 distributor, OBD1 ecu, and a 4 Wire O2 sensor and just hook it up.
You don't need the engine harness... just use yours.
Old Jan 28, 2005 | 06:14 PM
Nic's Avatar
Nic
http://www.locashracing.com
thats what is on my hatch back ecu harness subharness and disty harness
Old Jan 28, 2005 | 06:42 PM
krazie1's Avatar
BANNED
Default Re: (stk hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stk hatch &raquo;</TD></TR><TR><TD CLASS="quote">LoCashRacing.com
yeah that is the only place I know or heard of that has that jumper harness of the distributor
One of the first to do the K series swap in a CrX also or at least use the HaSport mounts for that
pretty dope
Old Jan 28, 2005 | 07:32 PM
Default Re: (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah that is the only place I know or heard of that has that jumper harness of the distributor</TD></TR></TABLE>
I have the distributor harness, but can never keep them in stock. So many people buy them like hot cakes.
Old Jan 28, 2005 | 08:01 PM
hondaguyef's Avatar
Default Re: (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
I have the distributor harness, but can never keep them in stock. So many people buy them like hot cakes.</TD></TR></TABLE>
Also w/ your harness you go color for color if you are making the Dizzy conversion yourself. With Locash you must go sensor for sensor(Correct me if I am wrong). JK Harnesses gets from me.
Phil
Old Jan 30, 2005 | 03:42 PM
NilsG's Avatar
Blown90hatch, do you ship to Sweden ?
PM me if you want...
Old Jan 30, 2005 | 04:50 PM
Samer's Avatar
Default Re: (NilsG)
If you're putting a b18b into your 90 Da no need to covert over to OBD 1. You can use your dizzy from your old motor and the complete intake manifold. If you use the b18b manifold you're gonna have to reroute vacuum lines which is kinda a pain. Non OBD manifolds have tons of vacuum lines. If you need more info PM me, we can talk.
The difference in the motors for b18a and b18b are the cams and the intake manifold.
Old Jan 30, 2005 | 06:09 PM
Default Re: (NilsG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NilsG &raquo;</TD></TR><TR><TD CLASS="quote">Blown90hatch, do you ship to Sweden ?
PM me if you want...</TD></TR></TABLE>
Worldwide!!
Old Feb 13, 2005 | 12:30 AM
NikoZai's Avatar
Rywire.com has the distributor jumper as well.
http://www.rywire.com/021dizzy.shtml
$25 shipped to the 48 states
We will ship out of country but require you pay shipping for that
Old Feb 13, 2005 | 05:18 AM
efcivic757's Avatar
Just put your dizzy on the new motor use your ecu and your o2 sensor. Would be a lot easier and cheaper to just convert the motor to obd0. I would stick with an obd0 motor. stronger than the obd1.
Old Feb 13, 2005 | 05:48 AM
b18CrxSi91's Avatar
71.179.86.205
Default Re: (efcivic757)
I used the JK Harness just yesterday to convert my buddies 89 hatch to OBD1, Simple and easy.
Good, Quality harness!
Old Feb 13, 2005 | 11:07 AM
user 98292739's Avatar
what about the fuel injector plugs? how are they modified? or do they need it? and i know i have to unplug the resistor box but which plug?
Old Feb 13, 2005 | 05:20 PM
Default Re: (LoCoReX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCoReX &raquo;</TD></TR><TR><TD CLASS="quote">what about the fuel injector plugs? how are they modified? or do they need it? and i know i have to unplug the resistor box but which plug?</TD></TR></TABLE>You do not need to run the OBD1 injectors. They are optional. IF you want to run them, probably the easiest way to do it is to solder on the OBD1 injector clips and take the plug at the resistor box and cut it off. Solder those 5 wires together to close the circuit. There are a few options for the injectors, cutting the injector to fit the OBD0 clips, depinning and using the OBd1 distribution plug for the resistor box.
JAson
Old Feb 13, 2005 | 07:14 PM
ok so i can take the a6 injectors out and put them in the z6 and thats it? that way i don thave to do any additional wiring and such? are they the same size fuel injectors?
Old Feb 13, 2005 | 08:40 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCoReX &raquo;</TD></TR><TR><TD CLASS="quote">ok so i can take the a6 injectors out and put them in the z6 and thats it? that way i don thave to do any additional wiring and such? are they the same size fuel injectors?</TD></TR></TABLE>
yea just put the a6 injectors in your z6. No additional wiring needed. Yes they're the same size.
Old Feb 13, 2005 | 08:44 PM
ShitBoxCrx's Avatar
please memorize this and next time someone says oh bee dee oh kick them in the testies.
Alex
Old Feb 13, 2005 | 10:01 PM
Default Re: (eda6)
THX! man i thought i had soem more headaches coming my way...thx god...
Old Feb 13, 2005 | 11:21 PM
RuthlessEF-9's Avatar
Jason saves the day again..your my hero Jason LOL
